LE 8.0 crashing on startup
I get the following error message on trying to open le 8.0
Process: Pro Tools LE [810] Path: /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE Identifier: com.digidesign.ProToolsLE Version: 8.0.0 (8.0.0f314) Code Type: X86 (Native) Parent Process: launchd [96] Date/Time: 2008-12-23 01:20:34.356 +0000 OS Version: Mac OS X 10.5.5 (9F33) Report Version: 6 Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000 Crashed Thread: 0 Thread 0 Crashed: 0 com.digidesign.mixer.stereo 0x1e7cac89 Dispatcher + 47483 1 com.digidesign.mixer.stereo 0x1e7f8c9d NewMachOPlugIn + 12951 2 com.digidesign.mixer.stereo 0x1e7fa9f3 NewMachOPlugIn + 20461 3 com.digidesign.framework.DAE 0x03f94f6a FicGetApplicationInterface + 82128 4 com.digidesign.framework.DAE 0x03f9366b FicGetApplicationInterface + 75729 5 com.digidesign.framework.DAE 0x03f947ca FicGetApplicationInterface + 80176 6 com.digidesign.framework.DAE 0x03fe1b5f FicReportExternalEvent + 161695 7 com.digidesign.framework.DAE 0x03fe2002 FicReportExternalEvent + 162882 8 com.digidesign.framework.DAE 0x03fba716 FicReportExternalEvent + 854 9 com.digidesign.framework.DAE 0x03f548fd FicMain + 69 10 com.digidesign.framework.DAE 0x03f5485f InitFic + 139 11 ...gidesign.framework.ProTools 0x020994cf Cmn_TypedException<Cmn_ANSIExceptionData>::Cmn_Typ edException(Cmn_TypedExceptionCode<Cmn_ANSIExcepti onData> const&, Cmn_ANSIExceptionData const&, Cmn_StackDump*) + 1852135 12 ...gidesign.framework.ProTools 0x02741d29 Cmn_TypedException<MA_OSErrData>::Cmn_TypedExcepti on(Cmn_TypedExceptionCode<MA_OSErrData> const&, MA_OSErrData const&, Cmn_StackDump*) + 3855205 13 com.digidesign.framework.DFW 0x008ec948 TCommandHandler::PerformCommand(TCommand*) + 86 14 com.digidesign.framework.DFW 0x008ed037 TCommand::Process() + 31 15 com.digidesign.framework.DFW 0x008e2182 TApplication::ProcessEvent(TEvent*) + 26 16 com.digidesign.framework.DFW 0x008e2068 TApplication::WakeUp() + 64 17 com.digidesign.framework.DFW 0x00955268 TApplication:oMakePrivateViewServer() + 3340 18 com.apple.HIToolbox 0x90656303 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181 19 com.apple.HIToolbox 0x9065573d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405 20 com.apple.HIToolbox 0x906555a2 SendEventToEventTargetWithOptions + 58 21 com.apple.HIToolbox 0x90683f14 ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 356 22 com.apple.HIToolbox 0x906566bc DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134 23 com.apple.HIToolbox 0x9065573d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405 24 com.apple.HIToolbox 0x90672092 SendEventToEventTarget + 52 25 com.apple.HIToolbox 0x906dec60 ToolboxEventDispatcher + 86 26 com.apple.HIToolbox 0x906db4ba RunApplicationEventLoop + 222 27 com.digidesign.framework.DFW 0x00943ce9 DFW_EventLoop::RunApplicationEventLoop() + 11 28 com.digidesign.framework.DFW 0x008e22a1 TApplication::Run() + 45 29 ...gidesign.framework.ProTools 0x0288cba2 LaunchProTools + 2266 30 com.digidesign.ProToolsLE 0x0000800c 0x1000 + 28684 31 com.digidesign.ProToolsLE 0x00002b62 0x1000 + 7010 32 com.digidesign.ProToolsLE 0x00002a89 0x1000 + 6793 THREAD 1-7 SEEM OK then: Thread 0 crashed with X86 Thread State (32-bit): eax: 0x00000000 ebx: 0x1e7f8bec ecx: 0x1bfd2a70 edx: 0x1e832ca8 edi: 0x00000063 esi: 0x00000000 ebp: 0xbfffdea8 esp: 0xbfffde90 ss: 0x0000001f efl: 0x00010286 eip: 0x1e7cac89 cs: 0x00000017 ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037 cr2: 0x00000000 Hope somebody can throw some light on the problem as I'd like to use the system for recording in Cuba next week Many thanks |
Re: LE 8.0 crashing on startup
The le 8.0 crash always occurs when the software launch is trying to open SignalTools.dpm
Is this the first time you've tried to launch PTLE 8? If so, I'd say the install went bad. Try uninstalling PTLE 8 and reinstall. Use the uninstaller on the .DMG you got with PT8 (or use the disc if you got one) and do a fresh install after a complete uninstall of PTLE 8. You shouldn't need to uninstall the third party plug ins, I don't think. Hopefully Digi will be able to chime in as well.
iMac C2D 2.16GHz 3GB OS 10.6.8 Focusrite Saffire Pro 40 PT 10 MacPro 8-Core 2.66Hz 16GB RAM MOTU Ultralite Hybrid PT LE 9.0.6 |
I had to remove DigiReWire plugin or else it would crash on boot up.
Hey Twix,
Your problem could be related to a conflict with Reason. Fortunately it's something you can fix. Try following these steps. Quit ProTools and navigate to your Macintosh HD > Library > Application Support. Inside this Application support folder, locate the following items and drag them to the Trash: Propellerheads Software ReWire Rex Shared Library The next time you launch Reason as a stand-alone application (not as a ReWire plugin in ProTools), those items will automatically be rebuilt. At this point, you should be able to move DigiRewire back to ProTools' plug-ins folder (Macintosh HD/Library/Application Support/Digidesign/Plug-ins), and launch ProTools without crashing. |
Pro Tools 9.0.5 crashing just after startup | ARTHANOR Productions | macOS | 16 | 11-24-2011 07:30 PM |
PT 9.0.5 Crashing on startup!! | eanderso22304 | macOS | 3 | 10-05-2011 11:31 PM |
Please Help!!! Protools 9.02 keep crashing during startup!!!!! | jothedrummer | macOS | 1 | 08-10-2011 07:34 PM |
PT LE Crashing on Startup | beggehorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-18-2006 09:18 AM |
protools crashing on startup help please | barkingdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-21-2004 08:38 AM |
