Re: Pro Tools 11 and High Sierra
"Unfortunately"? I love my Fusion drive. Is the issue that you can't partition it?
It has been a dogs breakfast for most as those drives are not aimed at audio recording. Errors and all around badness.
I've never had a problem, but I probably don't push Pro Tools as I am not primarily a sound editor.
If it works then thats great. No need to change until you actually have a problem oryou may not run into anything. It is just that there has been soo many issues with those iMac's that had Fusion drives that people go to that directly as the culprit but if you can use PT on the fusion drive then all is good
#16
"open the case". Ha! Easier said than done with an iMac!! Anyway, as above, it ain't broke, so I'm not looking to fix it. I think I for my limited use, I might check out Reaper as an alternative, given these issues. Anyone here ever try it?
#17
Doesn't matter. The Fusion drive moves data on and off the ssd part (which isn't all that big to begin with) at will and a lot of times I'm not sure but I think the spinner part of the Fusion drive is a 5400 rpm jobbie. And that makes it even worse.
#18
Reaper isn't going to help you any given that system drive you have. Any daw will have issues with that drive; some will be worse than others. And don't expect FCPX to run at all well with it either. |
#19
I'm not sure why you are so certain about the incompatibility of a Fusion drive. I've been using mine for four years for Pro Tools, Final Cut Pro, Photoshop and more and no particular issues ever. Maybe others have had problems, but not me.
#20
You may think you've not had problems but think back to any unexplained weirdness that happened. Things like PT slowing down, data glitches, etc. To say you haven't had issues only means you're whistling past the graveyard. |
S6L AVB with OS X High Sierra | brinnbacka | VENUE Live Sound Systems | 3 | 10-20-2018 12:52 AM |
Pro Tools with OS High Sierra (PROBLEMS) | B-flores | macOS | 9 | 02-06-2018 07:26 AM |
High Sierra | reichman | Post - Surround - Video | 4 | 01-04-2018 01:56 PM |
High Sierra | jeffpardo | Pro Tools 12 | 28 | 12-20-2017 09:39 AM |
High Sierra yet? | mlavin00 | Pro Tools 12 | 18 | 11-13-2017 10:09 AM |
