  #51
Old 10-03-2016, 01:24 PM
rossi68 rossi68 is offline
Default Re: can not maximize pro tools window???
I have had this issue from pro Tools 11, where I had to do the right-click-cancel routine, and now on pro Tools 12, where the only trick was to shut Down pro Tools and start again. None of the short cuts worked.
Then I found this thread. Removed the dvd disc from the drive, and, voila..
It worked :)
Thank you
But of course its a bug!!
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100
  #52
Old 01-08-2017, 04:51 AM
sbohonos sbohonos is offline
I just upgraded to 12.7 on my xw8600 Win 7 (x64) Pro machine and started seeing this minimization issue again. When I went to 12.6, it went away after it was happening in 12.5 (or at least I thought).
Turns out, the versions didn't matter, it was just coincidence that I must have had a DVD/Blu-Ray in one of my drives at those times. So, removing the disc was the work around for me.
If it does not fix other folks in Windows, I did a bit of troubleshooting before the fix and found something interesting. If I had my Pro Tools session up and actually *pressed* the Minimize button, then I had the issue where it would not come up with Alt+Tab and I needed to launch the Task Manager and 'Switch To..' to get back into Pro Tools. If I *did not press* the Minimize button of the Pro Tools window and wanted to switch over to say Chrome/Opera/etc and did so by either Alt+Tab or just switching to it with the mouse by clicking it on the task bar, then I was able to get back into Pro Tools with Alt+Tab or by clicking on it on the task bar. Minor subtlety, but I hope that makes sense.
  #53
Old 01-16-2017, 09:49 AM
leews leews is offline
Originally Posted by jeffro View Post
I see that you contacted support about this with PT 12.5.2 and they suggested checking for a disc in your optical drive (removing that allowed PT to maximize correctly). It might be helpful to hear from others if the presence of a CD/DVD is a factor or not. Thanks!
Thanks, jeffro. This worked! I am on version 12.2.1 and Windows 7.
  #54
Old 06-05-2017, 07:10 AM
SIGA.studio's Avatar
SIGA.studio SIGA.studio is offline
Yesssss...solved...when i removed the Cd from my optical drive, minimizing and maximizing r working normally...thx by the way im on win 10
Sent from my SM-A510F using Tapatalk
  #55
Old 07-25-2017, 05:53 PM
whole note whole note is offline
Hello -
I'm not sure if this thread is still active or the issue has been resolved, but I too am experiencing the same thing. I have PT 12.6 and Windows 8.1.
My upgrade and support plan has expired (due to money being very tight), so if Avid does issue a fix, I won't be able to get it. However, with that being said, this issue was never an issue (in my experience) of my earlier versions of PT...my earliest being version 8 up to 10, and then I jumped to 12, and that's when the issue occurred...in PT 12.6. Perhaps, Avid would provide an update to those people, like me, who no longer have a support/upgrade plan even though the issue was never an issue in previous versions.
Windows 10
Processor: Intel(R) Core (TM) i7-4700M CPU @ 2.40 GHz 2.40 GHz
Installed Memory (RAM): 16.0 GB
System Type: 64-bit OS, x64-based processor
ProTools 2018.7.0
Audient id14
  #56
Old 12-02-2017, 09:11 PM
jwrobopro's Avatar
jwrobopro jwrobopro is offline
Originally Posted by relder17 View Post
No optical disks in the drive. This problem happens on both of my completely different PCs. Very annoying, still hoping it gets addressed.
After living with this annoying bug for years
I finally found what was causing protools not to maximize
there was a disk in the optical drive wow.
now it works like it should. hmmmm
thanks Jeff
Jeffrey L Watkins
  #57
Old 01-28-2018, 02:50 PM
amagras amagras is offline
I'm seeing this approximately one version on, one off. It's back in 18.1
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #58
Old 01-28-2018, 03:04 PM
thanks Jeff
You are literally a genius! That was it, I had a virtual image mounted, right click>eject solved the problem!!!
amagrasmusic.com
  #59
Old 01-29-2018, 03:15 PM
Boborr Boborr is offline
Same here. I did have a disk in my optical drive. Removing it fixed the issue.... This happened on PT 2018, as well as 12.8.
However, before I read this thread, I could 'restore' PT by hitting only the 'Enter' key, (after selecting PT in the taskbar). Alt + Tab wasn't working
Bob
  #60
Old 05-28-2018, 10:07 PM
Alexlimbert Alexlimbert is offline
I'm having this issue now with Pro Tools 2018.4.0 using Windows 10
Maximize protools window stevedresser83 Pro Tools TDM Systems (Mac) 3 08-27-2010 09:39 AM
Maximize PT window in Vista/XP? albertors Pro Tools TDM Systems (Win) 3 02-26-2009 02:39 PM
Maximize edit window GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 10-23-2007 02:10 PM
Any keystroke or hot key to "Maximize" a window ? juanpatino Pro Tools TDM Systems (Mac) 3 10-05-2004 12:08 PM
Maximize Edit Window, but NOT Mix Dr Beamus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-13-2004 11:34 AM
