Old 11-29-2019, 07:50 AM
EddieJones's Avatar
Default Re: Pan
Originally Posted by dez811 View Post
Played with it today the pan worked for a sec then opened a different session and it stopped. Also when i hit the channel tab it is now blank nothing, nada is there this is annoying but like Eddie said in a previous post its free so I suppose I shouldn’t expect much even though i own a dock. Also i could be wrong but i thought when i went to the last tab where i can select which type of tracks i wanted to view like vca’s or aux’s etc. it was reflected in pro tools if it did work it doesn’t now. I think i liked it when euphonics ran the show
I'm not sure whats going on with this...I'm just hoping that the new Control App that comes out Wednesday will clear this up for you. Changing what is shown on the Control App never changed what was visible in PT, sorry.
FYI, I and many of the team are ex Euphonix ;-)
Old 12-03-2019, 10:04 AM
jwilkers jwilkers is offline
Default Re: Pan
I have the same issue with pan on the dock.
I looked and looked last night and it just was no where to be found.
I WAS on a very old session, so that could be it.
I have the latest and greatest everything except I do NOT have Catalina.
Luckily my Artist Mix works fine for Pan.
Old 12-03-2019, 10:05 AM
Default Re: Pan
Also, I brought up the Pro Tools 1 band EQ and there was no knob for Q, just frequency and gain.
Old 12-03-2019, 10:10 AM
Default Re: Pan
Personally I think Eddie does a great job.
I understand everyone wants everything to work properly.
I have been a programmer in the past.
You fix one thing and break something else by accident.
The dock and artist and now probably the S1 are some of the least expensive pieces of equipment for mixing and editing that you can buy.
They are very powerful.
Give them a chance before jumping ship or beating someone down.
(I have ZERO affiliation with AVID btw)
Old 12-04-2019, 09:17 AM
EddieJones's Avatar
Default Re: Pan
Hit the Sel button next to the Freq knob (this is the same for all EQs)
Old 12-04-2019, 09:19 AM
EddieJones's Avatar
Default Re: Pan
Thanks. It is very hard when only a couple of users have a particular issue especially given the 1000's of different configurations possible with EUCON (Mac/PC, OS version, PT or DAW versions, Surfaces etc.)
Old 12-04-2019, 10:27 AM
Default Re: Pan
I did not know that.
I have only been using surfaces for a short period of time and still use the mouse more than the surface as I learn.
Thank you.
