Re: 2020.3 on Windows 10 - video corruption and cannot uninstall
TD99 - also see reply above from JRV. I could not try that since I had already manually wiped 2020 from my system.
Pro Tools 2022.9 UAD Apollo 16 (v10.1) Dell XPS 8940 (i5-11400) Win10 www.studiodrumtracks.com www.doubledogrecording.com |
Not sure if this is useful or not but when reinstalling the video engine go into the public/public doucments folder and change the name of the Avid Video Engine folder to Avid Video Engine_Backup and when the video engine re-installs it will re-create this folder. This problem is an install failure.
This cannot be over-emphasized for Windows machines. It prevents all sorts of wierd issues from happening.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
I tried fully uninstalling everything before giving 2020.5 a try. Uninstall Pro Tools 2019.12, then uninstall all of the other pieces it does not uninstall... then reboot and install 2020.5. I get the same exact video/display/GUI corruption - the screen becomes unusable/unreadable - after bouncing a mix (actually during the bounce it starts). So frustrated. Avid support was useless when I tried to report it. Kept asking me to send samples of my video files - to which I repeatedly told them I was not using any... only audio or MIDI! uggh.
but at least the earlier tip on how to uninstall worked (using the "old" control panel).
Uninstalling Pro Tools 2019.12 Before uninstalling Pro Tools 2019.12, this worked for me: Renamed this Pro Tools Folder in C:\Users\Username\Documents\Pro Tools Renamed it: C:\Users\Username\Documents\Proof Cools Moved all my Avid stock plug-ins from: C:\Program Files\Common Files\Avid\Audio\Plug-Ins To: C:\Program Files\Common Files\Avid\Audio\Plug-Ins (Unused) Clicked on “Publisher” up top in Windows Programs & Features, to show all Avid products together. Uninstalled everything Avid which came installed by default: Pro Tools 2019.12 Avid HD Driver Avid Video Engine Avid Link Avid Cloud Client Services Avid Codecs LE Avid Effects FB360 Spatial Workstation AAX Falcon Ran CCleaner as well as CCleaner Registry (chose the Save Backup option) then restarted computer. Installed Pro Tools 2020.5 and Falcon 2.0.7 then restarted computer. Moved the contents from: C:\Users\Username\Documents\Pro Tools To the same Folder in: C:\Users\Username\Documents\Proof Cools Deleted this now empty Folder: C:\Users\Username\Documents\Pro Tools Renamed this Folder: C:\Users\Username\Documents\Proof Cools Called it: C:\Users\Username\Documents\Pro Tools Right-clicked on ProTools Application in: C:\Program Files\Avid\Pro Tools Selected: Properties then the Compatibility Tab Ticked the box that says “Run this program as an administrator” Hit Apply then hit OK Restarted computer Launch Pro Tools 2020.5 For others who require the 2020.5 Avid Video Engine, right-click on it from: C:\Program Files\Avid\Pro Tools\Pro Tools Utilities\Avid Video Engine Select: Properties then the Compatibility Tab Tick the box that says “Run this program as an administrator” Hit Apply then hit OK Install Avid Video Engine Restart computer Launch Pro Tools 2020.5, holding down “N” key to open the Playback Engine window, tick the Avid Video Engine box.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! Last edited by unkJE; 05-25-2020 at 10:30 PM. Reason: more info |
.ptx file corruption-missing audio and video files- no way to relink- | MikeReganNoise | Pro Tools HDX & HD Native Systems (Mac) | 102 | 04-28-2023 09:48 AM |
2020.3 High Sierra - Mac 5,1 - No Video playback | jseelye02 | Pro Tools 2020 | 3 | 04-27-2020 03:25 PM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
2020.3 Catalina video support | andystar | Pro Tools 2020 | 4 | 04-01-2020 11:43 AM |
New Avid Link 2020.1 - launched today 1/16/2020 | marianna | Licensing & Accounts | 8 | 01-16-2020 11:43 PM |
