  #31
Old 03-27-2014, 08:22 PM
Default Re: Pro Tools 10.3.7 Hard Freeze Computer Randomly
I would try for full clean OS etc. install as before, being careful to include no unneeded drivers and no third party plugins. But otherwise I fear Dave's comments may be right in your other thread. There are super great threads on DUC on how to build recommended i7 based systems.
Again, without stack traces/crash reports I would be careful not to assume you have exactly the same problem/cause as anybody else reporting a "system hang".
If this was my system I'd be setting up remote Windbg to try to debug the hung system and see what was going on/allow a crash report to be generated. That needs two PCs and experience with debug tools.
if you really have to try to get this to work, you may want to try contacting Avid support, yes I know you are in the UK.
  #32
Old 03-31-2014, 12:46 PM
uQbar uQbar is offline
Originally Posted by Michael.Joyce View Post
I have this exact problem.
Have there been any developments on this problem?
For me the solution was getting rid of all but a few tried and true AAX 32 bit plug ins. I've not had a crash since - whereas before I was getting the same behavior on two different set ups that had worked for years. I know a couple of others also have had success with this.
That said, your problem could be different. Easy test is moving all your 32bit AAX plugs to the unused folder and see if things get better.
  #33
Old 04-01-2014, 08:07 AM
Drywsef Drywsef is offline
This. AAX 32 has some problems it appears.
Win 10 - PT 12.4, maybe Studio One 3.2 soon - HD Native - Blue 192 - Prism Titan
My SANDRA report:
https://dl.dropboxusercontent.com/u/...Report%202.txt
OS/apps, sessions, and samples all on separate drives.
  #34
Old 07-08-2014, 09:15 PM
marcosdipaolo marcosdipaolo is offline
Hi all,
I write this coz I'm desperate, i'm working on a project and pro tools crashes over and over. Just like Pettah describes. Computer freezes completely and suddenly.
I already removed anti virus and created another user account, it happens with very light sessions as well, always after 30 min, 1 hour, it differs but it comes, always.
I read the event viewer and i dont find any errors, just information events which don't seem to be related.
I'm on
Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EP45-UD3
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz (4 CPUs), ~2.8GHz
Memory: 6144MB RAM
Available OS Memory: 6142MB RAM
edit. latest video and audio driver (MOTU)
Hope someone can help me
  #35
Old 07-08-2014, 11:27 PM
Originally Posted by marcosdipaolo View Post
Hi all,
I'm on
Memory: 6144MB RAM
If just freezing, are you sure the computer is freezing or just the Pro Tools application? Does it ever come back from frozen, or what are you doing to recover. Do you ever see a Windows bluescreen or application crash or Pro Tools failing with a DAE error? What exact error(s) do you get? Verbatim error text please.
You posted to a thread which is discussing plugin problems, so have you checked all your plugins are up to date and tried troubleshooting by removing all third party (AAX-32 and RTAS) plugins and putting them back in batches to see if you can identify plugins causing problems.
Is your system fully optimized? What other standard troubleshooting steps have you tried. Start at the "Help us Help You - READ THIS Before Posting!" link above on this an every other DUC page.
Post all your playback engine settings (a screenshot is ideal).
Post a full Sandra report, the snipet you gave is not enough. Run the Sandra report with all your disk drives, including the dedicated audio/session drives attached and indicate where sessions and samples are stored.
  #36
Old 07-15-2014, 12:40 PM
My PC freezes when Pro Tools is running only, actually I think it is when PT is running and using the Session Strings module in Kontakt 5, but i'm still not sure about that. The computer never come back from frozen state, a hard reset is needed. I get no errors or blue screen, not any kind of message, the computer suddenly and totally freezes.
If you explain me how to do it I'd like to try that with the kontakt 5 but I think i can use kontakt
as long as i don't use session strings, but again I'm not sure yet, i need to test more.
I've already done the help us help you troublesghooting guide and system optimization guide.
Screenshot:
About the Sandra report here i post the System overview and the HDD reports, all sessions and sample libraries are stored in the secondary drive STORAGE (D:)
Code:
SiSoftware Sandra
ID
Host Name : Marcos-PC
Workgroup : GRUPOMARCOS
Computer
Model : GigaByte EP45-UD3
Chassis : GigaByte Desktop
Mainboard : GigaByte EP45-UD3
BIOS : Award (OEM) F9 01/27/2010
Total Memory : 6GB DIMM DDR2
Processors
Processor : Intel(R) Core(TM)2 Quad  CPU   Q9550  @ 2.83GHz (4C 2.83GHz, 2x 6MB L2)
Socket/Slot : FC LGA (Socket T)
Chipset
Memory Controller : Gigabyte P45/P43/G45/G43 DRAM Controller 4x 333MHz (1.33GHz), 2x 3GB DIMM DDR2 800MHz 128-bit
Memory Module(s)
Memory Module : Corsair CM2X2048-8500C5D 2GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-18 3-23-6-3)
Memory Module : Kingston 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Video System
Monitor/Panel : ACR V193HQ
       (1366x768, 25.0")
       (1366x768, 25.0")
Video Adapter : AMD Radeon HD 5700 Series (10CU 800SP SM5.0 850MHz, 1GB DDR5 4.8GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 5700 Series (800SP 10C 850MHz, 1GB DDR5 4.8GHz 128-bit)
Compute Shader Processor : AMD Radeon HD 5700 Series (800SP 10C 850MHz, 1GB DDR5 4.8GHz 128-bit)
Storage Devices
Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm) : 1TB (C:)
Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm) : 1TB (D:)
TSSTcorp CDDVDW SH-S223Q (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
System (C:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm)
Storage (D:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm)
Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-S223Q (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Gigabyte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8718F
Audio Device : Gigabyte HD Audio Controller
Audio Device : ATI (AMD) EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Gigabyte 4 port SATA IDE Controller
Disk Controller : Gigabyte 2 port SATA IDE Controller
Disk Controller : Gigabyte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Gigabyte USB UHCI Controller #4
USB Controller 2 : Gigabyte USB UHCI Controller #5
USB Controller 3 : Gigabyte USB UHCI Controller #6
USB Controller 4 : Gigabyte USB EHCI Controller #2
USB Controller 5 : Gigabyte USB UHCI Controller #1
USB Controller 6 : Gigabyte USB UHCI Controller #2
USB Controller 7 : Gigabyte USB UHCI Controller #3
USB Controller 8 : Gigabyte USB EHCI Controller #1
FireWire/1394 Controller 1 : Gigabyte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Printer : HP Deskjet F4400 series (600x600, USB, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Code:
SiSoftware Sandra
SCSI General Properties
Controller : 0
Bus : 0
Target ID : 0
Logical Unit No. : 0
General Capabilities
Model : ST31500341AS
Manufacturer : Seagate
Height : 3.5"
Interface : SATA
Revision : CC1H
Serial Number : 9VS4****
Latest Firmware
Version : ZZ7L
Date of Manufacture : martes, 15 de julio de 2014
Update URL : Not available in this version (Lite).
To enable it, get support and other benefits, please upgrade.
(Goto 'Help - Get More: Upgrade')
Channel : Master
Type : ATA
Interface : SATA
Removable : No
Manufacturer : Seagate Technology
MAC Address : 00:50:00:C5************
Revision : CC1H
Serial Number :           **********
ATA/ATAPI Version : 8.41
Rotational Speed : 7200rpm
Drive Geometry
CHS Geometry : 16383 x 16 x 63
CHS Total Sectors : 16514064
LBA Total Sectors : 2930277168
No. ECC Bytes : 4bytes
Capacity : 1.36TB
Properties
NCQ - Native Command Queuing : Yes
PEC - Physical Event Counters : Yes
LBA Support : Yes
Features
S.M.A.R.T Support : Yes
Security Support : Yes
Power Management Support : Yes
ACPI Power Management : No
Power-up in Standby : No
Packet Command Interface : No
Removable Media : No
Look-Ahead Buffer : Yes
Write-Back Cache : Yes
Host Protect Area : Yes
Microcode Update : Yes
Acoustic Management : Yes
48-bit LBA : Yes
Device Config Overlay : Yes
Active Features
S.M.A.R.T Enabled : Yes
Security Enabled : No
Power Management Enabled : Yes
Look-Ahead Buffer Enabled : Yes
Write-Back Cache Enabled : Yes
Host Protect Area Enabled : Yes
Acoustic Management Enabled : Yes
S.M.A.R.T Information
Version : 1.01
ATA Commands Support : Yes
ATAPI Commands Support : Yes
S.M.A.R.T Commands Support : Yes
S.M.A.R.T Data
Raw Read Error Rate (01) : 120 (6 - 99) [0E8220B1]
Spin-up Time (03) : 100 (0 - 92) [00000000]
Start/Stop Count (04) : 98 (20 - 98) [0000084B]
Re-Allocated/Retired Sector Count (05) : 97 (36 - 97) [0000008C]
Seek Error Rate (07) : 83 (30 - 60) [0D6304FB]
Power-On Time (09) : 91 (0 - 91) [0000218B]
Spin Retry Count (0A) : 100 (97 - 100) [00000000]
Power Cycle Count (0C) : 99 (20 - 99) [00000662]
Bad Block/End2End Error Count (B8) : 100 (99 - 100) [00000000]
Uncorrectable Error Count (BB) : 100 (0 - 100) [00000000]
Command Timeout Count (BC) : 100 (0 - 99) [00010002]
TBD : 1 (0 - 1) [000000E6]
TBE : 62 (45 - 54) [26150026]
Drive Temperature (C2) : 38 (0 - 46) [00000026]
ECC Corrected/Program Failure Count (C3) : 50 (0 - 28) [0E8220B1]
Pending Sector/Read Failure Count (C5) : 100 (0 - 100) [00000000]
Un-Correctable/Read Sector Count (C6) : 100 (0 - 100) [00000000]
CRC/Write Sector Count (C7) : 200 (0 - 200) [00000042]
Head Flying Hours (F0) : 100 (0 - 253) [00002152]
Total blocks (LBA) written (F1) : 100 (0 - 253) [342A4AAC]
Total blocks (LBA) read (F2) : 100 (0 - 253) [5A13C7C3]
Sensors
Power-On Time : 357 day(s), 19 hour(s)
Disk Enclosure Temperature : 38.00°C
Transfer Modes Support
I/O Queue Depth : 32
Block Size : 16
Maximum SATA Mode : G2 / SATA300
Transfer Modes Active
Current Block Transfer : 16
Current SATA Mode : G2 / SATA300
Translation Mode Disk Geometry
CHS Geometry : 182401 x 255 x 63
Bytes Per Sector : 512bytes
Capacity : 1.36TB
Cache Information
Read Cache : Yes
Write Cache : Yes
Prefetch Buffer : No
Partitions Information
Partition 1 : MBR Boot IFS-NTFS 1.36TB
Logical Drives
Logical Drive : C:
Performance Enhancing Tips
Tip 1803 : Disk firmware update available. To update, visit the manufacturer's website.
Warning 3103 : Acoustic Management enabled. Performance may be impaired.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Code:
SiSoftware Sandra
Controller : 0
Bus : 0
Target ID : 1
Height : 3.5"
Interface : SATA
Revision : SD17
Serial Number : 9VS0****
Latest Firmware
Version : ZZ7L
Channel : Slave
Type : ATA
Interface : SATA
Removable : No
Revision : SD17
Drive Geometry
LBA Total Sectors : 2930275055
Capacity : 1.36TB
Properties
LBA Support : Yes
Features
Acoustic Management : No
48-bit LBA : Yes
Device Config Overlay : No
Active Features
Version : 1.01
S.M.A.R.T Data
Raw Read Error Rate (01) : 117 (6 - 99) [07222175]
Spin-up Time (03) : 93 (0 - 92) [00000000]
Start/Stop Count (04) : 98 (20 - 98) [00000AEE]
Re-Allocated/Retired Sector Count (05) : 98 (36 - 98) [0000005A]
Seek Error Rate (07) : 83 (30 - 60) [0C405C93]
Power-On Time (09) : 82 (0 - 82) [00003EF7]
Power Cycle Count (0C) : 98 (20 - 37) [00000AE5]
Command Timeout Count (BC) : 100 (0 - 97) [0046017A]
TBD : 1 (0 - 1) [00000127]
TBE : 63 (45 - 55) [25150025]
Drive Temperature (C2) : 37 (0 - 45) [00000025]
ECC Corrected/Program Failure Count (C3) : 48 (0 - 22) [07222175]
CRC/Write Sector Count (C7) : 200 (0 - 200) [00000000]
Sensors
Power-On Time : 671 day(s), 15 hour(s)
Disk Enclosure Temperature : 37.00°C
Block Size : 16
Capacity : 1.36TB
Cache Information
Read Cache : Yes
Write Cache : Yes
Logical Drives
Logical Drive : D:
THANKS IN ADVANCE
  #37
Old 07-15-2014, 03:37 PM
Default Pro Tools 10.3.7 Hard Freeze Computer Randomly
You have non-identical DIMMs, I would fix that.
You should not have samples on your audio/session drive. Put them on the system drive or on a dedicated hard drive.
You only have a 4 core (nonhyperthreading) system, yet have all 4-cores dedicated to plugin processing. That may be part of the system locking up. Set NCPU=3, 99% and uncheck ignore errors (you want to see what exact errors get thrown) and leave them that way while you debug other things.
You need to do a lot of debugging of your plugins, make sure you remove all third party plugins from the plugin folders (RTAS and AAX), and see if the problem goes away, put individual plugins back and see which one may be causing problems--it does not even need to be instantiated to cause problems or it may be interaction of several plugins.
  #38
Old 08-07-2014, 08:15 AM
mlange's Avatar
mlange mlange is offline
Has there been a consensus reached on NI with PT HD 10.xxxx?
We have the following six errors in our Win7 event log:
Activation context generation failed for "c:\Program Files (x86)\Avid\Pro Tools\DAE\Controllers\D-Control_Resource804.dll". Dependent Assembly
Activation context generation failed for "c:\Program Files (x86)\Avid\Pro Tools\DAE\Controllers\D-Control_Resource412.dll". Dependent Assembly
Activation context generation failed for "c:\Program Files (x86)\Avid\Pro Tools\DAE\Controllers\D-Control_Resource404.dll". Dependent Assembly
Activation context generation failed for "c:\Program Files (x86)\Avid\Pro Tools\DAE\Controllers\003_Resource804.dll". Dependent Assembly
Activation context generation failed for "c:\Program Files (x86)\Avid\Pro Tools\DAE\Controllers\003_Resource412.dll". Dependent Assembly
Activation context generation failed for "c:\Program Files (x86)\Avid\Pro Tools\DAE\Controllers\003_Resource404.dll". Dependent Assembly
FWIW, we have never owned or used a D-Command or 003 with our current system...... we're on PT HD 10.3.8
________________________
www.PlethoraTone.com
PlethoraTone Studio Video Tour
At PlethoraTone:
Intel Core i7-4960X, Asus P9X79 LE, W7 Pro 64-bit, 16GB DDR3,
Avid HD Native, Pro Tools HD v10, 4/192 I/O, 2/UAD-2 QUAD,
Tascam US-2400, Exponential Audio, PSP, Kush, Slate Digital,
Waves Mercury, PA, Melodyne, Antares, Audioease, SoundToys
  #39
Old 10-05-2015, 03:26 PM
Bittenfleax Bittenfleax is offline
Default Might of found a fix! It works for me.
So, after looking into it for a while I found multiple things. I am not sure which thing fixed it for me but on of them did. Here is what I did:
1. Go into "Services" and find 'Desktop Windows Manager'. I right clicked and went to properties and on the recovery tab on "Subsequent failures" I selected "Restart the Service".
2. I set Pro Tools to "High priority" in task manager.
3. I moved the Libary that was crashing my PC onto my SSD. Now also, the reason why I did this is because when using it on MAC the same thing happened, but only when the hard drive was full of rubbish. So I though "I will move it onto my SSD". I guess it worked, also now (2015) you can get a 240GB SSD for £70 compared to 2013 where it was A LOT more expensive.
TL;DR, it could just be write speed not being enough and people kept crashing because no one had SSD's a few years ago and now they are more common so people might be able to fix.
Hoped this help, PC specs on my profile. (AMD-A10, 8GB RAM, 120GB SSD, 2x 1TB HDD's)
PT10 Sound goes fuzzy / distorted randomly; also get hard freezes dan0082 Windows 2 10-19-2013 12:37 PM
Computer Freeze Pro Tools 10 rickstar44 Windows 8 01-27-2013 04:02 AM
computer randomly freezing for a few seconds to several minutes audiogeekzine Pro Tools M-Powered (Win) 2 09-30-2010 07:41 PM
Plug-in meters freeze randomly Dr. Bockman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-10-2005 02:08 AM
computer shuts down randomly! Help please illsub1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2002 08:22 PM
