  #391
Old 12-13-2013, 09:03 AM
Raoul23 Raoul23 is offline
Default Re: Pro Tools 10 Freezes
Originally Posted by louieshowers View Post
i found that i would get more sound artifacts and system crashes whenever working with elastic audio.
Strange never suffered from any of those issues ?????
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #392
Old 12-13-2013, 09:25 AM
Drywsef Drywsef is offline
I've also experienced instability when working with elastic audio. No system crash, but pro tools will hang and quit every time.
Win 10 - PT 12.4, maybe Studio One 3.2 soon - HD Native - Blue 192 - Prism Titan
My SANDRA report:
https://dl.dropboxusercontent.com/u/...Report%202.txt
OS/apps, sessions, and samples all on separate drives.
  #393
Old 12-13-2013, 09:43 AM
louieshowers louieshowers is offline
Sorry...I actually meant program crashes...but it causes me to reboot in order to reopen protools.
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
  #394
Old 12-13-2013, 09:44 AM
Maybe because I am using Vanilla PT as opposed to HD?
PT 10.3.8
  #395
Old 12-14-2013, 12:56 AM
wdjudd wdjudd is offline
I've found 10.3.5 to be the best and most stable version of Pro Tools 10HD. I went to 10.3.7 and after a week reverted back to 10.3.5
I realize that the following is an accurate representation for my system and may not be applicable to yours.
After several days [three weeks of he _ _ ] of trying to get 10.3.7 to work properly, and having little success, and pis _ _ _g off a couple of consistent clients, I reverted back to 10.3.5. Although 10.3.5 is not without issues, it has been much more stable than 10.3.7. All of the freeze issues discussed in this [and other related threads] still persist in this version for me, except if I create a new 32 bit session and only add a few audio tracks and master fader with NO PLUGINS, then for the most part the session is stable for a while but not consistently.
By stable I mean that the screen freeze when changing plugins does not happen because there are no plugins loaded. Also, when the space bar is pressed to start the session, the transport usually starts as expected. However, after I add a few plugins, save the session, close the session and then reopen the session, depressing the space does not result in transport movement . . . it freezes and the only way to get it to work is to change the buffer size. Since a lot of users seen to experience these issues, I am convinced that this is not an isolated issue to my system.
The audio artifacts that are referred to in these threads do surface from time to time and the only way I can get rid of them is to delete prefs [etc.], and reboot system. Then I get a short reprieve. During a four hour session I can count on having to restart at least four times to reset ProTools so that it works as expected. Because of this problem, in the preferences I set backup copies to 80 at 5 minute intervals. This bails me out at least once per week.
Things I have tried to correct these issues . . . most everything any one has mentioned in these threads [members and AVID] including uninstalling/reinstalling ProTools, and also reinstalling Lion several times. I have also gone through as many associated files that I could find that the new installers seem to leave behind - yes leave behind.
I would like to have hopes that AVID will release a 10.3.8 update with fixes for these reoccurring issues but I have little confidence that they will expend the resources to support 10.3.x. I hope they prove me wrong.
Best of luck. If all else fails, uninstall 10.3.x and reinstall v9. It was at least for me a much more stable system and you can stop wasting time for constructive responses from AVID. Let alone a 10.3.8 update, which I do think we will ever see.
ProTools LE/Native 10.3.10, 002R, Sibelius 6.2
OSX 10.9.5; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 32 GB 1333 MHz DDR3 ECC; Internal Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB
  #396
Old 09-16-2016, 12:22 AM
mrdmn mrdmn is offline
Is it someone who have a solution for this problem yet?
I have big problems whit freezing computer and then I most restart it the hard way. Have PT10 and tried a lot of stuf in this thred but nothing happands. Tried windows 7 and 8 but same same. This is so frustrating.
Thanks!
pro tools 10.0.1 freezes ewlewl macOS 3 11-02-2012 02:39 PM
Pro Tools HD freezes mac pro gaspari99 Pro Tools TDM Systems (Mac) 11 12-22-2009 01:38 PM
pro tools freezes uzi B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-26-2009 06:29 AM
pro tools freezes LonnyS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-05-2006 01:19 PM
Pro Tools Freezes Up TMCguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-09-2005 10:11 AM
