I can't drag and drop with Structure free.
I want to sample using structure free but when I try to drag the audio into the plug in it doesn't work, nothing happens, I was watching a tutorial on how to use it and that's what you're supposed to do figures it doesn't work for me.
Intel i7-4770k, AMD Radeon HD 7870, 8gb G.skill 1600mhz, MSI G45-Z87 Gaming, Samsung Evo 840 120gb, 3tb Toshiba, Corsair CX750M, Fractal Design R4, Win 7 Ultimate 64bit & OSX Yosemite, Asus 27" MX279H |
Re: I can't drag and drop with Structure free.
lol Well how do I do it now?
I don't use Structure so I don't know
I would crack open the PDF guide and look it up, I'll assume there is a load command
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
nope, it's pro tools so having a guide that actually tells you how to do something wouldn't make much sense, I read through the PDF guide for Structure Free and there is nothing about sampling songs.
I disagree. The new version 2.0.2 still struggles in that department. Sometimes it drags, most times it doesn't. The best solution: use Kontakt instead.
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
Kontakt appears to be $400 I can't afford that I guess I should know better than to expect things to work
You can't drag an audio file in structure but you can import it. I'm not at my production computer at the moment so I will have to a little walk through later.
alright
Structure: No Drag and Drop?? gone in aax | Rectifried | AAX Plug-ins | 10 | 11-08-2013 10:56 AM |
Structure - next patch or only drag/drop? | andrewpiano | Virtual Instruments | 5 | 05-18-2010 07:14 PM |
Bug in Structure free drag and drop | BR Rundfunk | Virtual Instruments | 0 | 02-10-2009 07:26 AM |
Structure Drag n Drop stereo from PT | arild | Virtual Instruments | 0 | 09-25-2007 08:21 AM |
Structure drag n drop | pindebraende | Virtual Instruments | 58 | 09-16-2007 03:46 AM |
