Old 05-16-2019, 02:56 PM
SteSo SteSo is offline
Default Re: Adjusting Clipgain with jog wheel in PT 2018.12 causing Pt to crash
After working a while with PT 19.5, PTC 19.5, new OS 10.13 it´s really a big pleasure to edit and mix with the dock and the artist mixes. Even the EQ, Dyn cycling works as I wanted, great. Using the Jog Wheel without crashes again makes the work more efficient, but this obviously should be the normal condition.
But with this, it´s even more frustrating not to be able to switch off the shift function for the artists. As I´m very often in shift mode for wheel functions (Clip Gain etc.), I´m always struggling with this transport functions, when I´m soloing or muting VCA Groups on my mix panels. That´s really a bummer.
Other question is about the Eq and Dyn layout in the Channel Mode. When I select an EQ (FabFilter) via the insert function in PTC it has a completely different layout to the selection via EQ. That makes one option really useless. As there was no EQ/Dyn Cycling before, I wrote all my presets for the insert select option. Now it´s much quicker to choose the EQ via EQ select, but the layout is a jungle. Can´t this be unified? Would be very helpful.
Last thing I recognized is, that the wheel function for Mark In and Out is always forgotten after a restart. Maybe I have to reinstall EU-Control, maybe it´s a common bug.
So far, Stefan
Old 05-17-2019, 07:47 AM
EddieJones's Avatar
EddieJones EddieJones is online now
The EQ and DYN Layouts are set in the EUCON SDK and all developers should follow it and should be the same for any EQ/DYN. The idea is to make it predictable.
Old 05-18-2019, 05:46 AM
Hi Eddie,
we´re talking here not about the same things. I wonder why the PTC Layout of the EQ´s or the Dynamics is not the same when I choose them via the Inserts tile versus choosing them via the EQ (or Dynamics) tile in Cannel Mode.
Both layouts differ completely for the 8 control knobs. And this has to be a reason in PTC, because the same issue happens with Avid EQ´s or Compressors.
That makes one option completely impractical.
Cheers, Stefan
Old 05-18-2019, 07:26 AM
EddieJones's Avatar
As I said they are different. The EQ and DYN ones are set so that every plugin appears the same on the surface. The inserts are up to the plugin developer and allows them to add controls that are not in the default EQ/DYN layouts
Old 05-21-2019, 12:12 AM
Ah ok, I get your (Avids) Point.
good to know.
Scroll Wheel Crash listnersupported Pro Tools HDX & HD Native Systems (Mac) 1 03-06-2012 04:53 PM
UAD-1 and DigiRewire causing crash??? help read my crash log pherzfeld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 06-14-2008 07:38 AM
Spinning wheel of death when adjusting video colin1 Pro Tools TDM Systems (Mac) 2 04-10-2007 11:33 AM
Crash when adjusting Instrument track MIDI volume Helge Krabye Pro Tools TDM Systems (Mac) 0 01-28-2006 02:33 PM
Scroll Wheel Speed Adjusting? dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-28-2004 09:43 AM
