Old 10-09-2010, 09:28 AM
accession accession is offline
Default Spinning ball, can't save, can't relaunch PTLE, reboot then drive unreadable!
As per the title, has happened twice now.
PTLE 8.0.4, running an external FireWire drive from the Digi002R.
Simple session, around 12 x 30sec clips, 2 soft synths, duplicate a simple kick drum MIDI loop several times. Hit play...
...spinning ball for a few minutes, finally clears but can't save (-50 error), close PTLE, but session nor back-up sessions won't load (-9126 error), reboot computer to discover hard drive now won't mount, OS and Disk Utility says drive unreadable and needs to be initialised.
This is the second time this has happened recently since updating to 8.0.4. I don't normally run an external drive from the Digi002R, but need to while my rig is downsized for an impending move across the country.
Any ideas?
Kinda scary, and thank goodness for (semi-) recent drive back-ups.
Old 10-09-2010, 03:45 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: Spinning ball, can't save, can't relaunch PTLE, reboot then drive unreadable!
You probably already checked this, but have you checked to see what your hard drive was formatted too?
Old 10-10-2010, 12:40 PM
DigiTechSupt's Avatar
Any ideas?
The -50 is an OS error - here's a link or two about it:
http://reviews.cnet.com/8301-13727_7-10342945-263.html
http://support.apple.com/kb/TA22339?viewlocale=en_US
This could be a number of things - file directory corruption, drive format corruption, the drive just plain going bad, etc.
When you say this is the second time this has happened - is it with the same drive? If so, it's likely the drive is going bad and may need to be replaced. You should back everything up off it, erase it using Disk Utility, then copy all data back - but use it with caution!
Also, make sure you're not using illegal characters anywhere in your drive, folder or file names. Usually you would get a different error if that were the case, but sometimes computers can be quirky...
Avid Audio Tech Support
Support FAQ
spinning beach ball of DEATH vs. PTLE Chickenhawked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-24-2010 10:42 AM
PTLE 8.0.1 vs spinning beach ball of death Chickenhawked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-24-2010 10:37 AM
HELP!! I save... spinning ball of death... what the.. indiemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-19-2009 03:41 AM
Spinning ball on save? Kelly M. Pieklo Pro Tools TDM Systems (Mac) 1 02-22-2007 12:53 PM
Spinning ball Mubeau Post - Surround - Video 5 08-15-2006 11:42 AM
