Old 08-18-2019, 01:11 PM
Default MIDI editor zoom
Since I've moved to PT 2019.6 I've had a problem with the MIDI editor and the zoom that comes up by default. When I first did some editing in the MIDI editor window things were zoomed way out both vertically and horizontally. So I zoomed in horizontally no problem using the +/- keys in the lower right of the window. I then figured out how to do the vertical zoom for the upper window where the notes are. This last bit is something I never had to do in PT11.3.2 but such is life. Went about matters for that session.
Then today while working on another session I had to do some editing in the MIDI editor window. The zoom levels I set in the above mentioned session were not used and once again everything was squished both vertically & horizontally. Is there a preference setting I'm missing? For the most part preferences I had set in PT11.3.2 were carried over but this one - not so much. Tried looking in the manual but it's not all that clear. Also tried looking online and using the Google site operator to search the DUC and found nothing that would help.
PT 2019.6
OSX 10.12.6
Is the zoom setting in the MIDI editor global or per session? IOW set it once and every session from now until eternity has that same zoom set in the MIDI editor?
Old 08-20-2019, 04:31 AM
Default Re: MIDI editor zoom
Buehler?
Buehler?
Since I posted the other day I've not had the zoom retention issue. Wish I knew what was going on.
Old 08-20-2019, 03:01 PM
xrekcor's Avatar
xrekcor xrekcor is offline
His name is Murphy
Originally Posted by musicman691 View Post
Buehler?
Buehler?
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 08-20-2019, 03:17 PM
Originally Posted by xrekcor View Post
His name is Murphy
So no one's seen this then?
Like I say it hasn't reappeared (as he knock on wood)
Old 08-20-2019, 03:42 PM
xrekcor's Avatar
Haven’t seen it here. but I have a later mOS ver than you.
Rob
Old 08-21-2019, 04:00 AM
That could well be. I know Sierra is on the lower hairy end of being considered compatible. As I wrote I thought it might be due to a preference that either changed between PT11 and 2019 or opening session that were started in PT 11.3.2 and then worked on in 2019.6. But what puts the lie to that is other sessions that I started in PT 11.3.2 are okay wrt MIDI zoom and not having to reset it.
1) Zoom with scroll wheel. 2) Open midi editor camawe macOS 5 09-19-2012 08:40 AM
MIDI - re-spell accidentals in Score Editor, and MIDI zoom nhwinni Pro Tools 9 4 09-08-2011 10:14 AM
MIDI Editor - zoom out problem bongish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-06-2010 04:46 PM
Midi editor goes wacko !!!!! Zoom is dead... Aquarius Pro Tools TDM Systems (Mac) 20 09-06-2010 04:26 PM
MIDI editor won't zoom out suicune Pro Tools TDM Systems (Mac) 1 03-21-2009 05:30 AM
