AMD Ryzen 9 5900X
AMD Ryzen 9 5900X
Curious if anyone is using this processor on their PC? Or any comments or insights as to recommended alternatives. Thanks |
Re: AMD Ryzen 9 5900X
Great question. I'm planning to do a MB/CPU/ram upgrade fairly soon, and am considering an Intel i9-10900k/Z490 or i9-11900k/Z590. I'm also curious about that AMD chip. Anybody?
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
I use it, I'm getting CPU overload problems due to high sample rates (anything above 1024 samples) but it works perfectly fine with other DAWs.
Please clarify. High sample rates or high buffer?
I did a bit of looking into the 11900k and was shown this review, which is not favourable (an understatement). I am reconsidering using it in my upcoming build.
https://www.youtube.com/watch?v=mxiuvQPL_qs I am now looking at a possible Ryzen build using the 5900x. Did you end up going for the 5900x?
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+ Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9 |
My main Pro Tools system has a Ryzen 5950X CPU in it. I run Process Lasso and make sure to disable SMT aka hyperthreading in Pro Tools using that app, and my performance is solid. Did a feature documentary mix and some reality show mixes on it with very high track and voice counts, with dense automation all over the place. Unfortunately for any bigger post projects of a collaborative nature, the lack of Spanner really stops Windows from being viable still. Hoping Cargo Cult and/or Avid do something about this soon. At this point with the recent versions of Pro Tools I'm almost thinking the SMT disabling thing may even be a legacy/superstition kind of thing that I may be able to get away with re-enabling, but haven't tried that under any serious kind of workload yet. One thing that is vital in Windows 10 is to get your system's DPC latency under control. The free Resplendence LatencyMon Home Edition will help with this. Last edited by polyh3dron; 05-20-2021 at 03:01 PM. |
I have a 5950x rig. ProArt Creator b550, with HDSPe MADI in a TB/PCIe chassis (node 2 duo)- also used with Quantum.
These processors are incredible for audio, particularly for low latency audio (provided the rest of the system works properly). I can have a huge session, with a ton of VI's and track a full 16 mics on a drum set, with lots of inserts and heavy send FX like abbey road plates etc AND arm Diva and record along with the drums at the 32 sample buffer. In fact, I have never changed the buffer setting from 32. I did have a chance to compare to M1 MBP (same interface), which is also better than intel in low latency performance, and for single core low latency (using reaper for both, only one channel loaded, FF Pro-R AS Native), the 5950x is capable of roughly double the instances as the M1. M1 capable of roughly 50% more than 7980xe- all at the 32 sample buffer. The differences between all 3 get smaller as the buffer sizes go up, but the 5950x leads all the way. For me this is the native HDX killer. I'm finally back to that TDM workflow (arm any track at any time without thinking about latency), but without being tied to AAX-DSP plugins only (or PT only) and having that horsepower for VI's as well. |
Is it really true that the 5950x can run at 32 samples? Can anyone else confirm?
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
I'll make a video here when I get a chance- I can make 32 mono tracks, each with Pro-Q3, Pro-C2, Softube Console1 and Arturia STA as well as 10 tracks of diva at the default preset, all with two sends to abbey road plates and arturia plate, arm all 42 tracks and record on all of them (playing on the keyboard to max out all 60 Diva voices) at the 32 sample buffer. I have never had the need to raise the buffer above 32... |
Ryzen 32 core | tabonik | Pro Tools 12 | 13 | 09-30-2021 07:41 AM |
AMD Ryzen 9 vs Intel i9 | New_Selas | Windows | 7 | 12-09-2020 10:36 PM |
AMD Ryzen 3rd Gen and PT 12 | Lagelos | Windows | 2 | 04-01-2020 01:45 AM |
AMD Ryzen processors | gcasper | Windows | 14 | 05-08-2017 01:39 AM |
Pro Tools 11 and AMD Ryzen CPU's | griff71177 | Pro Tools 11 | 51 | 05-08-2017 01:38 AM |
