boost::filesystem::path codeccvt to wstring: error
Hi. I get this message when trying to launch izotope neutron2 inside PT 12. Not every time, but most times. It is followed by automatical shut down. Does anyone know what´s wrong? Thx. Jonas
Re: boost::filesystem::path codeccvt to wstring: error
Have you contacted the offending party?
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Are you saying that there´s a offender at work here, like a enemy inside my computer? / Jonas
What do you mean by automatic shutdown? Is PT crashing to desktop? Some system info would help as you have none listed. While waiting for that I did a Google search for your error message and a common thing that came up in a couple of answers was illegal characters in a file name. Here's a hint for others in the same boat when you see an error message that you don't know the immediate answer for: try Googling the exact error message. You may get some help that way. |
Definitely contact Izotope. The error mentions the file system, so maybe the plug-in can't deal with some characters for your region properly.
Thx, guys. I just tried opening the compressor plug-in from neutron 2 and it was without a hitch. It´s funny that it can render different results like that. Since the error occurs inside PT, is it therefore a AVID or a izotope issue? During these crashes i´m asked to send info to avid and i always do, but i don´t really know where it goes from there. Also, perhaps it matters, when i open the izotope plug-in it sometimes turns up all white, like blank. The GUI frame opens, but the specific izotope GUI inside the frame isn´t there. I hope i make sense here.
Some of my specs are: PT 12 (2018.12), HP Z420 with Windows 10 Pro, 64-bit, Intel Xeon E5-2680 2.70 Ghz, 64 RAM. I use a apollo twin interface. I believe it crashes to desktop, if i understand correctly. It goes from open to exiting and program closed. I then need to re-open. I did try to google the exact error, but i really can´t tell what´s what with this. I lack so much in computer skills. I´m contacting izotope first out and go from there. Please let me know your thoughts. / Jonas |
I got this from AVID and it seem to work so far.
Try re-installing the plugin. It might have been corrupted and causes Pro Tools to malfunction. I would also recommend to optimize your system for Pro Tools to run smoothly. I haven´t heard from izotope yet. Easy fix to a seemingly serious error:) Håll tummarna, as we say in sweden. Thx, guys. |
Path error each time I open a project | Sam C | macOS | 16 | 01-15-2013 05:18 AM |
path definitions error | travista00 | Pro Tools TDM Systems (Mac) | 2 | 02-02-2011 05:39 PM |
DAE Error - Path not found Error | rattledaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-18-2006 06:54 AM |
what is the best type of filesystem for audio hd? | bryan_s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-23-2005 11:17 AM |
optimum filesystem (ntfs vs fat32) and partition size? | hanzoid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-18-2003 04:01 PM |
