Old 07-27-2018, 03:05 PM
jamesleonard jamesleonard is offline
Default How would I connect the Roland TR-8S to 003 Work Surface (PT 2018.4.0), through USB2?
I have the Roland TR-8S.
I have a USB2 cable... but there may be a problem - as I think I have to plug it into the 003 control surface...
The back panel (003), has two firewire ports (FW400, IEEE 1394 6 Pin), however, in one of the ports I have the: Thunderbolt to Firewire Adaptor - which connects the Mac and 003.
I don't think the Roland TR-8S is going to work on Pro Tools - by plugging into the ports at the back of the Mac ... will it?
I need to plug it in the 003 - but I cannot do this because of the firewire ports.
Even then... How would I configure the internal settings in Pro Tools to allow the Roland TR-8S to play - through USB?
I have never used USB cables with external hardware in Pro Tools - only external hardware with midi cables in Pro Tools.
Is there a solution - and would it be easy to configure Pro Tools for the TR8-S - when everything is 'set-up.'
Old 07-27-2018, 04:08 PM
Sardi Sardi is offline
Default Re: How would I connect the Roland TR-8S to 003 Work Surface (PT 2018.4.0), through U
It has analog outs. Plug those into your 003 inputs.
Use the USB or MIDI connections if you want PT to output MIDI info to trigger the sounds on the TR8-S.
It functions just like any other piece of equipment. If you’re new to using external instruments, maybe flick through the manual so you get an idea how to set it all up.
Old 07-27-2018, 05:25 PM
Is it true that: Audio over USB sounds rubbish?
I have no problem configuring the Eight analog i/p interfaces in Pro Tools for receiving incoming sound from an external midi module... or assigning sounds to individual outs - which belong to any external midi hardware units
I just thought I would give USB2 a go... As i have never used it before in that way - I thought it would/might be better as it behaves rather like a Multichannel Audio Digital Interface - with no hum.
Is this how it (USB2) behaves?
Old 07-27-2018, 11:18 PM
Sorry. I wasn’t aware the USB on that was for a soundcard.
Whoever told you USB over audio sounds bad doesn’t know what they’re taking about.
If you want to use it as a soundcard with your 003 you’ll have to set it up as an Aggregate IO otherwise it will be one of the other.
Old 07-28-2018, 10:19 AM
How do you that? I have been at it all day
Could someone from Pro Tools or Roland 'chime-in' I'm getting 'nowhere fast' here
This is crazy........
Old 07-28-2018, 07:10 PM
https://support.apple.com/en-au/HT202000
Old 07-28-2018, 10:23 PM
I have done all that... and I can't seem to make any headway
Like I said before I have a 003 going to the iMac (thunderbolt to firewire adaptor) I have only the 003 workstation - which is sufficient for what I do at home.
I have set my session at 24bit/96kHz (this is what Roland stipulate...) and watched the Kevin Becka videos (countless of times), see link below:
Free Tutorial - Using Pro Tools Aggregate I/O & I/O Setup To Speed Your System Workflow Part 1 – Quickly Jump Between Tracking, Overdub, & Mixing I/O Setups:
https://www.pro-tools-expert.com/hom...y-sized-system
... I have looked at your link and plenty, plenty more (etc. etc.) - as you can well imagine
I just cannot seem to get my head around it. I have configured the aggregate I/O countless of times and can't get any sound from it and it doesn't seem to register on the meters in pro tools either
I have no problem navigating back to my 003 setup. i.e.: The Playback Engine Avid 003 - that is easy enough
However, this aggregate i/o setting is 'something else' and I have been trying to get this to work for 18 hours
Surely it can't be that hard to do... Can it? AAAGGGHH!
Edit//: In this short video: 2.13 minutes... This man succinctly explains how to do it - however, this is setup in Ableton Live. At 1.19 you can see the USB2 (TR-8S to Mac)
Roland TR-8s Tutorial: Connecting Audio to Ableton Live
https://www.youtube.com/watch?v=6tVB...&frags=pl%2Cwn
This guy explains the configuring (it is a TR8 - but it is basically the same thing)... and it is more in-depth, unfortunately it is on Logic (someone PLEASE do a video with Pro Tools... What is the matter with you lot )!
Using Multiple Outputs with the Roland TR-8
https://www.youtube.com/watch?v=N58jVASFeVs&frags=
Someone PLEASE do a Pro Tools Video (quickly)! Is he using Instrument Tracks or Audio tracks????
I am still struggling with this function and I cannot get it to work.
Last edited by jamesleonard; 07-30-2018 at 04:04 PM. Reason: I was very tired last night and omitted relevant details.
Old 03-25-2020, 03:19 PM
Anmlboy Anmlboy is offline
Did you ever figure out how to connect the tr8s to pro tools. Having major issues as well. I can get midi sound but not the tr8s sounds
OS 10.13.5 - will PT 2018.4 or .5 work well or stay with 2018.13? blankpro Pro Tools 2018 4 07-11-2018 07:22 PM
Avid connect 2018 Lane McGiboney Post - Surround - Video 4 02-18-2018 02:33 PM
Will the Digi 002 (2005 model) Work Somehow with Dell Laptop w/USB2 or USB3? Blue Ridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-04-2011 09:43 PM
Roland VS1680 as control surface? thefridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-18-2008 10:20 PM
