Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 10-16-2013, 08:17 PM
Jurupari Man Jurupari Man is offline
Default Integrating UA Apollo w Pro Tools 10
Just replaced my Digi 002 with an Apollo. I've hit a stumbling block, which I'm sure is a total no-brainer, but I'm just stuck. I'm unable to get a signal through to Pro Tools for recording a track. I've got signal to my mic pre, signal to the Apollo, signal on the on-screen Apollo console... Using Analog 1 on the Apollo, and I have the input set to Analog 1 on the track I'm trying to record. Put Pro Tools in record, and no signal. What am I missing or doing wrong? Thanks in advance!
Old 10-17-2013, 05:54 AM
quantise quantise is offline
Default Re: Integrating UA Apollo w Pro Tools 10
The first thing to check is that you are in "Pro Tools Mode" which is in the settings for the Console.
This will allow your PT I/O to line up with the Apollo I/O and not be offset by two tracks.
Apollo works well with PT.
PTHD 12.8.3 TB Native + Avid 8x8x8. Universal Audio Apollo 8p and Apollo 8 plus SF Apollo Quad used as outboard.
MacBook Pro 15-inch 2017. 4-Core 2.9 GHz Intel Core i7. OSX High Sierra 10.13.2
Avid S3 and Softube Console 1. Dynaudio BM5's.
Old 10-17-2013, 06:34 AM
Hi. Yes, I did select PT mode in the console settings window.
Old 10-17-2013, 07:42 AM
Southsidemusic's Avatar
Try setting all your i/o in PT to Default. All pages like Aux IN OUT etc and try again.
Apollo Quad and Apollo 16 works great here w/10HD & 11HD
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 10-17-2013, 07:56 AM
That did it, Southside - thanks!
Old 10-17-2013, 08:04 AM
Glad it worked Great Interface
Best Regards
Chris
Best Regards
Christopher
WEBHOME
Old 02-21-2014, 01:07 PM
cruisemates cruisemates is offline
Out of curiousity - once you start using any UA interface - what are your choices for a controller? Can you use a digi003, or are you precluded from that because it is also an interface?
Can you use one of the newer Eucon devices from Avid?
- but the second mouse gets the cheese
Old 02-22-2014, 09:26 AM
Barry Johns Barry Johns is offline
No 003.
Command 8, about 350 used
Artist Units, about 1 k used, but not well implemented
Mackie Control, about 700 used, built well, but limited implementation
There are more, depends on how much you want to spend, and how many faders you want.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 10-10-2014, 06:27 AM
dgbt dgbt is offline
Southside, are you using a quad and a 16 together as one interface? If so, how are you doing this?
Old 10-19-2014, 03:33 PM
latinbaum latinbaum is offline
I just replaced my Digi 002 with an Apollo. I'm unable to get a signal through to Pro Tools for recording. I've got signal to the Apollo, but NO signal on the on-screen Apollo console. I'm using Analog 1 on the Apollo, and I have the input set to Analog 1 on the Pro Tools track. I put Pro Tools in record, and no signal. Already selected PT in the Apollo and reset everything to default in the I/O panel on Pro Tools.
I'm running Pro Tools 10 on A MAC Pro 12 Core
Can you help me.
Apollo Duo v. RME UCX for Pro Tools drkwb5 Pro Tools 10 0 03-18-2014 06:25 PM
Mac Pro 2013 + Pro Tools 11 + UA Apollo Quad fsguerra macOS 1 03-11-2014 08:15 PM
Does anyone know if two UAD Apollo 16 can be used at the same time with Pro Tools? Zarabozo Pro Tools 11 7 07-16-2013 10:38 PM
Help for integrating new gear into pro tools Texas Studio C Pro Tools TDM Systems (Mac) 4 06-08-2007 03:08 AM
Integrating 001 with Gigastudio cbarrett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-25-2003 10:53 AM
