Old 09-28-2019, 08:32 AM
RichrdC RichrdC is offline
Default The current playback engine does not support a sample rate of 96 kHz
Good morning,
I have a Lenovo laptop, 16 gig Ram, with a Qcon Pro X control surface and an MBox 3 for connecting guitars etc. So I go to open a session, and I'm greeted by this message, that the playback engine doesn't support 96 Hz.. In the Setting tab, I see the playback engine. I see the Mbox selected, 512 sample rate, but I don't see where to look at the Hz numbers..Is this something to look at in the Mbox 3 control area? I looked but was worried about playing around in there.. I'm perplexed. Can someone explain this error to me, and where I might go to fix it? Thank you
Old 09-28-2019, 08:58 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: The current playback engine does not support a sample rate of 96 kHz
Hi please check at windows sound panel if your mbox is selected as default playback device by win, if so, select your onboard audio as default and try again.
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 09-28-2019, 08:59 AM
jeam25's Avatar
Also double check you have the correct lastest driver for your mbox/os.
Protools Ultimate
Old 10-01-2019, 04:25 PM
Well, I checked my Windows sound settings and yes, Mbox was selected so I went with the Real Tec High Definiition for both soundout & mic. I have the newest drivers for the Mbox 3, and I still got the reeor message... I wish I was a better detective.
Old 10-01-2019, 04:27 PM
JFreak's Avatar
JFreak JFreak is online now
Are you sure PT is using that for playback? Press and hold 'N' while launching PT so the playback settings window opens first.
Janne
Old 10-02-2019, 09:12 AM
The Weed's Avatar
The Weed The Weed is offline
Set the Realtek as default for everything under Control Panel>Sound and Disable anything else you see under there. Then do as Janne suggested, Hold down "N" while launching Pro Tools and see if you can get the Playback Dialogue screen and choose the Mbox as the engine.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-02-2019, 12:01 PM
Thank you for the ideas. I will report back with the results.
Old 10-05-2019, 04:32 PM
Just wanted to say thanks to Moderator Jean. Mbox was default sound & when changed to the inboard, the error went away.. Thx much
Old 10-06-2019, 05:16 AM
JFreak's Avatar
No problem. And yes, Janne is Jean in french
Janne
Old 10-15-2019, 06:48 PM
Sorry Janne.... Sometimes I can't read!!
Current Playback Engine does not Support a Sample Rate of 48 Hz Glide Pro Tools 12 13 02-08-2017 02:49 PM
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
the current playback engine does not support a sample rate of 44.1 khz bzerk Pro Tools 12 11 05-03-2015 07:13 PM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
The current playback engine does not support a sample rate of 48 kHz oNeKOG Third Party Interfaces 3 09-08-2014 04:36 PM
