Old 03-17-2016, 05:08 AM
boomish69 boomish69 is offline
Default Connect an old 192 to Avid HD i/o?
I'm working with producer that has a relatively new HD system , new Mac Pro, Expansion , Native cards and a HD i/o , can I connect his old 192 via the expansion port for extra I/o?
Appreciate any help, am finding conflicting advice via a google search
Old 03-17-2016, 05:41 AM
Drew Mazurek's Avatar
Default Re: Connect an old 192 to Avid HD i/o?
Yes. I have an Avid HD I/O 16x16 connected to a Digidesign 96I/O connected to an Apogee Symphony I/O 16x16. All works perfectly.
In my situation the only caveat is that the Apogee can't be first, even though it's my primary interface.
Also, while they use the same protocol, the newer Avid boxes use Mini Digilink connectors whereas the 192s have regular (larger) Digilink connectors. So you'll need an adaptor cable.
www.drewmazurek.com
Old 03-17-2016, 08:00 AM
Yes - no problem.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-17-2016, 09:13 AM
YYR123's Avatar
YYR123 YYR123 is offline
OT - why the 96? Doesn't that mess your global Cal up? The 96's are -14 iirc and the 192's and HDi/o's are all -18 default iirc
Sorry to hijack....but if we are talking about mixing and matching I believe that Global Calibration is a legitimate subtopic....
Daniel
Old 03-17-2016, 09:59 AM
Both are 16 IO
Old 03-17-2016, 10:14 AM
96 only does headphones (use to do AFL/PFL as well before Avid "fixed" the I/O Setup in PT12).
Avid and Apogee do all the heavy lifting.
www.drewmazurek.com
Old 03-17-2016, 11:41 AM
Thanks for all the replies, yep hooked it all up and worked straight away, 24 analogue & 8 digital i/o now!
Avid Connect Announcements 2015 marianna General 0 04-11-2015 03:51 PM
Avid Connect 2015 | 4.10.15 - 4.12.15 marianna General 1 04-11-2015 09:54 AM
Apogee Thunderbridge to connect AVID HD I/O? producerdna Pro Tools HDX & HD Native Systems (Mac) 1 03-04-2013 08:31 PM
ProTools HD7.1 can not connect with Avid Mojo Janvy Pro Tools TDM Systems (Mac) 4 03-08-2012 10:07 PM
