Old 11-03-2013, 08:32 PM
bryced87 bryced87 is offline
Default Proper Recording Levels
What should my proper recording levels be? I've read many opinions and I'm not sure what is the right one. Some say record using Prefader turned on and the input level should never hit Yellow. Others say it should be Halfway into the Yellow Others Say it should be almost clipping. I have peak turned on in the Mix window and right now it's set to -10db
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 11-03-2013, 08:58 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Proper Recording Levels
Just hitting yellow should be perfect. There's no reason to push the level towards clipping in a DAW. The main reason you would do so on an analog/tape system is to get well above the tape noise/hiss, plus the saturation of the tape can sound nice - neither of those aspects applies in a digital system where the dynamic range is greater and digital clipping gets nasty.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-04-2013, 10:23 AM
DMB13KOS DMB13KOS is offline
Exactly - to those of us with a tape background, the first thing to learned with digital audio is that there is no need to record as hot as we did when we burned in tape.
Old 11-04-2013, 11:47 AM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
That took me a bit to get use to Having learned to record to tape was a hard habit to break
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 11-04-2013, 11:50 AM
Drew Mazurek's Avatar
Actually, we're still recording to the same levels that we always did.
What people don't realize is that 0dB VU (+4dBu) is only -18dBFS on most PT interfaces. So when you're just into the yellow in PT, you're actually running your analog gear right where it wants to be.
www.drewmazurek.com
Old 11-05-2013, 08:03 AM
Thanks, Drew, I really did not know that - assumed the metering was the same.
Old 11-05-2013, 08:27 AM
JFreak's Avatar
JFreak JFreak is offline
Metering is the same, if you mean the lowest is in the bottom and the highest is on the top
Seriously though,
Analog and digital are two different animals. If you go over digital zero, it sounds nasty. That is an absolute limit, and we need to preserve some headroom to be safe. Analog though, that is kind of relative. Yes there is a reference level but what does it mean? Your voltages are the same as everywhere, but then again there are lots of different sounding analog gear and different sounding tapes and if you stay safe or ride rough those are different sounds. In digital domain that sound shaping does not happen. Only thing you need to worry is never go red.
So that's why yellow is the new red. Hitting yellow is just as good as hitting 0 VU and it just leaves you plenty of headroom so you don't have to worry about levels at all. Really. Not at all, if you stay low enough.
And if you want numbers, here you go:
- best AD converters have about 120dB dynamics
- 24 bit digital word has 144dB dynamics
==> if you use your converters to their fullest, you have about 24dB headroom
In other words, anything hotter than -20dBFS is just amplifying noise and leaves you less headroom.
Janne
Old 11-05-2013, 10:46 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
0dB VU (+4dBu) is -18dBFS
+1
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 11-05-2013, 11:53 AM
jewa jewa is offline
This is a really good tutorial on levels: http://www.youtube.com/watch?v=B-Qm6NFIY2E
Old 11-05-2013, 12:55 PM
Glad to help with the little I do know in this area.
www.drewmazurek.com
Question on proper levels LongRoad Tips & Tricks 11 06-14-2009 03:56 AM
rca recording levels/proper interface channel rygar22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-07-2005 12:21 AM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 01:32 AM
Proper recording/monitoring of vocals MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 08-16-2004 11:15 PM
*Recording Levels* mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-03-2002 09:10 AM
