Phantom Power
I have a question about phantom power. Should you have your mic attacthed first then activate phantom power or the other way around? Or does it not even matter. I of course have levels down to aovid any pops or boom noises .
I just want to make sure if there is a procedure for using phantom power |
Re: Phantom Power
Connect the mic first. Also, turn phantom off and let the mic sit for a minute or two to dissipate the energy.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Re: Phantom Power
It's a good rule of thumb to always connect the cables, then power up.
Re: Phantom Power
Thanks for the tips
Re: Phantom Power
A big one to look out for is when you are patching mic inputs on a patchbay (TRS style). If you patch while phantom power is on, it is very easy to send 48volts down the active wire when the tip of the plug brushes past the earth in the patch plug.
When you hear a mic become a speaker it can really bring a tear to your eye. |
I wouldn't want a patchbay connected to a Mic. I've heard some people do this but sounds dangerous lol.
Sent from my HTC Thunderbolt using Tapatalk
www.M-ManLA.com www.facebook.com/MManLA www.soundcloud.com/m-manla Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro |
Re: Phantom Power
I've always prefered the mic ins to be on seperate XLR patchbays. Less room for error
Re: Phantom Power
I agree.
Re: Phantom Power
Something you guys might want to check out...
In the SSL AWS 924 Manual (we all can dream!), they discuss a specific type of patch panel that can be used for mic lines. I think that the jacks are "special" and are wired in a certain way so that there is no problem patching even with phantom power on. You can download the manual on the SSL web site, and if you guys are able to figure out (or already know) anything else about this, please post it. I would agree that XLR patch bays are the way to go for mics, but if the SSL thing is a viable alternative it would be good to know...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Re: Phantom Power
most ever big studio in LA has it's mic lines to pre ins on standard patch bays
usually full normal but i've seen half done as well
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Phantom Power | paulrgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 12-11-2009 12:39 PM |
002R Faults + power harness + no phantom power | DaveSB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2009 01:10 AM |
recording with phantom power *and* without phantom power simultaneously | SweetSoulSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-22-2008 07:40 PM |
Phantom power and mic with power supply? | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2005 12:56 PM |
Phantom power | optymusblu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 09-10-2003 09:19 PM |
