Old 05-09-2001, 02:53 AM
kenny j kenny j is offline
Default How do you group selected objects in the edit window ?
How do you select all objects(ranges?)to the right of the edit point? In order to move them as 1 ?
Also how to create a continuous sound effect with no gaps from the one object (range)?
kenny j
kenny j
Old 05-09-2001, 07:14 AM
DigiTechSupt's Avatar
Default Re: How do you group selected objects in the edit window ?
1-Click and drag with the Selector Tool to highlight the area and then use the Grabber Tool to move the selected area (Slip mode)
2-Shift+Tab to select the area to the right of the insertion cursor and then use the Grabber Tool to move the selected area (Slip mode)
-If I understand this correctly: Highlight the section of audio and then use the Duplicate AudioSuite plug-in to create a single, continuous file.
Brent
Avid Audio Tech Support
Support FAQ
Old 05-10-2001, 12:01 AM
Roy Howell Roy Howell is offline
Kenny,
Also, there is a little button just below the 'Grid' button in the upper left hand part of the Edit Window. It has Up and Down arrows on it. Make SURE it's highlighted or you can't select ALL the tracks at once to the left(or right) of the edit point.(I can't recall what the button is called right now).
Once you've highlighted your desired section, you can COPY, then click the point where you want it, and hit PASTE and there it will be.
I hope this helps. Roy
rh music
Pro Tools 8 Problem All tracks are selected for everything in edit window. DONNX Pro Tools TDM Systems (Mac) 16 08-30-2021 04:31 AM
Key Command Edit Window Change Track Height All Selected? DFT Pro Tools 10 3 03-08-2013 02:20 AM
Edit window - everything selected bug still not fixed! Marsdy macOS 1 11-02-2012 10:48 AM
View Selected Region in Edit WIndow? blastula Pro Tools TDM Systems (Mac) 2 03-20-2008 05:16 AM
wherever i click in my edit window all tracks are selected stephendavis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2007 10:13 PM
