Closed Thread
Old 07-21-2023, 02:13 PM
sricabla sricabla is offline
Default New to Reamp on a Mac
I recently bought a Walrus Audio Reamp box.(I have never Reamped before) I do not record real amps and cabinets but through amp sims. I have an Apollo Twin X. I believe that I might have the box connected correctly but I don't really know for sure because it has not worked for me yet. I haven't used a DI box, but what I do in place of a DI box is record with the amp sim and then bypass the amp and I get a clean tone.
(I still have the waveform of the amp sim on the track. Don't know if that makes a difference)
1. I connect the Line out (3) from the Apollo to the input(XLR)on the Reamp
box.
2. I connect the Line out from the Reamp box to the front of the Hi Z input on
the Apollo. I believe this is the correct way to connect, but I am not positive.
This is where I am totally confused, is the routing. If you see the attached, I have the "clean and DI" on the top and just have the output on MON L-R.
The lower track is the REAMP track. Ignore the I/O on that track. I open the IN and where do I go? I see many choices which do not lead me to anything.(see attached) Then there's the busses which I have not included.
If anyone can give me a hand on this I will send good vibes to you for your help.
Thanks in advance!
Old 07-21-2023, 02:47 PM
Default Re: New to Reamp on a Mac
Duplicate of https://duc.avid.com/showthread.php?t=425335
Please follow the DUC guidelines and do not post duplicate threads, doing so just wastes other users time here with repeated conversations potentially going on in both threads.
Closed Thread
Reamp out of 002r jhkillam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-22-2014 05:23 PM
11R Reamp through Axe FX Webb Eleven Rack 12 09-27-2011 07:59 AM
How do you Reamp using 11 Rack? tom hess macOS 3 02-07-2011 12:36 PM
Has Anyone Used REAMP with 001? MissHiss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-26-2003 11:00 AM
Reamp? nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-27-2000 11:33 AM
