Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 12-17-2020, 11:23 AM
WinTaper WinTaper is offline
Default PT Setting like "Recording Delay" in Logic?
Is there a setting in Pro Tools that is analagous to the "Recording Delay" setting in Logic (under Preferences | Audio)
This setting allows me to compensate for the fixed buffer in my interface (SSL Alpha-Link) that Pro Tools does not (cannot) compensate for.
This is NOT a part of Automatic Delay Compensation, nor is it a "Hardware Insert".
To demonstrate the problem, record a click-track on Channel 1. Playback and send output (DA->AD) to Channel 2 (like a bounce through your interface). Record the results, check alignment of clicks on CH 1 and CH 2. They will be off (in my case 81 samples).
No matter what sampling rate or "hardware buffer" I set, the result is always 81 samples... which is expected because thats the buffer in the SSL. Pro Tools has no way of knowing about that buffer, so it cannot compensate.
I'm guessing that Avid interfaces somehow report this value back, since I don't see the issue with Avid interfaces.
I've been working around this for years using the manual compensation setting at the bottom of each track, but it would be really great if this were an actual feature.
- Dan
Pro Tools 2020 | Mac OSX 10.15.x
RME Ray-DAT | SSL Alpha-Link AX
2019 Apple Mac Pro 16 core / 96GB
Old 12-17-2020, 12:51 PM
daeron80 daeron80 is offline
Default Re: PT Setting like "Recording Delay" in Logic?
I've seen that with many Digidesign interfaces over the years. The 888, which was Avid's (Digi's) flagship interface in the mid '90s also had a 80-some sample roundtrip. It's less than 2 ms, and thus negligible for most purposes. You only really need to adjust stuff if you're sending audio to external processing and back.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 12-17-2020, 01:31 PM
It is necessary when doing overdubs and punch ins. Otherwise, the best a musician can hope for is to be 81 samples behind the beat. 81 samples at 48kHz is quite noticeable. And then the next session guy comes in 81 samples behind that. Before you know it, you have a problem.
I guess I'll stick with manually compensating on a track-by-track basis. I much prefer PT to Logic.
- Dan
Old 12-17-2020, 01:37 PM
Actually that setting is supported in the "Setup | I/O | HW Insert Delay" preferences setting, but that applies to insert roundtrip... not recording input.
Also always wondered why that setting is expressed in time instead of samples, since time will vary by sampling frequency, whereas samples will not.
- Dan
Old 12-18-2020, 07:22 AM
I've never met a musician who was accurate within 2ms, and I spent 15 years with the best in Nashville.
David J. Finnamore
Old 12-18-2020, 07:50 AM
Emi's Avatar
Emi Emi is offline
- Dan
+1000000000000000
I never understood that. It would be so So SO simple in samples, and waaaaaay more accurate.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Eq to make acoustic recording sound "plugged in" or "live" Jt06 Pro Tools 12 4 03-08-2017 10:13 PM
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
setting levels "naturally" vs. what "the books" say Felix Tips & Tricks 8 12-19-2001 05:23 PM
