Old 03-06-2018, 04:15 PM
BScout BScout is offline
Default Eucon 2018.3 Problems - Monitoring Mute No Longer working
So... 2018.3 was posted today.
New release had a Dock firmware update. Everything went smoothly for both the Eucon install and dock update. Went to go mute the DADman outputs (for the MTRX) and doesn't work anymore. Pressing down on the monitor knob doesn't "cut" the output. However, doing it via the DADman software, the red light next to Monitor still works on the Dock to show it is cut. Volume also still works with the Dock. DADman is on 5.2.0.14 and was working just fine until I did this Eucon/firmware update.
Could use some help here. Minor annoyance but I often mute/unmute the outputs throughout the day.
(To be absolutely clear, when DADman is in focus, Artist Mix and Control App both work muting/cutting the channel and the light works on the dock as an indicator. Only the push on the Dock Monitor knob does not work, whether DADman is in focus or not (but locked in Eucontrol))
Old 03-07-2018, 11:25 AM
EddieJones's Avatar
Default Re: Eucon 2018.3 Problems - Monitoring Mute No Longer working
We found the issue and fixed it. Hopefully by tonight I can switch out the installers with the fixed version. I'll keep you posted.
Old 03-07-2018, 02:54 PM
Thank you. Never realized how much of an irritation losing that control would be.
Old 03-07-2018, 07:59 PM
EddieJones's Avatar
New files are up. They should end in 219 (not 217)
Old 03-07-2018, 08:13 PM
Great. Installed and once again working like it should. Many thanks for getting the fix out so fast.
Pro Tools 2018.1 low latency monitoring issues stakeoutstudios Pro Tools 2018 61 04-15-2020 07:15 AM
Pro Tools 2018.1: Error in Controller-Personality "EUCON" ... johab Pro Tools 2018 0 03-02-2018 01:40 PM
SLATE RAVEN - NOT working with PT 2018.1 Seafoam_Green Pro Tools 2018 12 02-13-2018 11:47 AM
Low Latency Monitoring no longer working. SevenRising Pro Tools 12 2 12-30-2017 11:54 PM
Low Latency Monitoring no longer working... ryanstewartguitar Eleven Rack 7 06-16-2014 01:24 PM
