Old 02-19-2014, 05:55 AM
WinTaper WinTaper is offline
Default Is delay compensation necessary for Master Fader on Main Outs?
When mixing down, is it necessary to use delay compensation for plugins on the master fader? I have a few favorites that are pretty high latency - forcing larger playback buffer setting than I would normally use. I'm wondering whether it would be ok to simply disable delay compensation on the master bus and use my normal playback buffer size.
I'm talking about mixdown only - not tracking - with all track outputs being sent to the main outputs. I've tried both ways and it seems to work fine without. It seems to make sense - any thoughts?
-dan
Pro Tools 2020 | Mac OSX 10.15.x
RME Ray-DAT | SSL Alpha-Link AX
2019 Apple Mac Pro 16 core / 96GB
Old 02-19-2014, 05:57 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Is delay compensation necessary for Master Fader on Main Outs?
Originally Posted by WinTaper View Post
When mixing down, is it necessary to use delay compensation for plugins on the master fader? I have a few favorites that are pretty high latency - forcing larger playback buffer setting than I would normally use. I'm wondering whether it woulkd be ok to simply disable delay compensation on the master bus and use my normal playback buffer size.
-dan
No you can disable delay comp on the mix bus and master fader etc!
if using video in the session you might need to use it!
Chris
Producer, Engineer,
www.ukmastering.com
Delay Compensation on Master? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-19-2011 12:10 PM
Delay Compensation + Master Track twix Pro Tools 9 10 08-27-2011 03:52 PM
Manual Delay Compensation on Master Fader? browniespeaks Tips & Tricks 11 05-05-2010 10:34 AM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 12:02 PM
Delay Compensation on Master Fader musicnutt2000 Pro Tools TDM Systems (Mac) 1 09-12-2006 04:08 AM
