Old 11-05-2013, 04:33 AM
TDub TDub is offline
Default Re: White bursts of noise and I/O device error ?! HELP
Got it! Thanks for all of your help, really appreciate it.
Good news is, after copying all of those files over to a different drive, they seem (knock on wood, only tried a couple so far) to be working ok as far as the static noise part.
Still got this error once, when playing just a small file for some reason: "DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or a firewire drive could be having trouble due to extra firewire bandwith or CPU upload". So not sure if that has to do with video driver.
But at least the static seems better so far. Going to try the video driver next.
TDub
Digi002 R with Command 8 - PTLE 8.03
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 11-05-2013, 05:40 AM
jeam25's Avatar
jeam25 jeam25 is offline
Glad you nailed it..!
Then you can download the motherboard chipset drivers too and install
the lastest version ...the error might be the storage device driver ...
Good luck !
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 11-05-2013, 06:52 AM
sunburst79 sunburst79 is offline
You might want to run a low level error check on the old drive using the manufacturers bootable DOS Utilities disk and do a complete error check. But make sure its backed up someplace else first.
If your confident of our backup(s) you might try erasing the drive and doing a low level format. Keep in mind this WILL destroy any data on the drive. Once its formatted copy the files back. If that doesn't fix things it would tend to indicate that you may have some corrupted files.
I've seen the low level format sort drives out once and a while. Especially those that have had the power shutoff while writing or saving files.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
White noise bursts gemada Pro Tools SE and Essential (Win) 6 06-20-2011 12:51 PM
PT9 White Noise Bursts therecordinghouse Pro Tools 9 1 11-19-2010 10:12 AM
White Noise Bursts in PT9 mattytoldhatty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-15-2010 05:35 PM
Bursts of white noise Danielle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 01-24-2004 06:30 AM
White Noise Bursts with 6.1.1 LE M BOX jamieoliver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-03-2003 10:39 AM
