Old 03-21-2013, 11:00 AM
grateful grateful is offline
Default How do I record enable multiple instrument tracks in a group?
Hello,
I created a group of instrument tracks consisting of two violin tracks plus a cello and viola track- a total of 4 tracks. I can only record enable one track not all 4. I want to volume automate them as a group with a modulation wheel, so each track must be record enabled.
Please tell me how I can record enable all four tracks.
Thanks for your help,
Grateful
Protools 8.0.3
003 Rack
OSX Leopard 10.5.8
2.66 GHZ Intel Core 2 Duo
4 GB 1067 DDR3
Old 03-21-2013, 11:09 AM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: How do I record enable multiple instrument tracks in a group?
Im a little confused... You say you have Instrument tracks (Is this Virtual Instruments?)?
Are you trying to just automate the volume?
2 ways to do that....
Group them and then set the VI tracks to "Write automation" and during playback If you move one of the audio faders they will all move and write automation data. After write I usually put it in latch or touch mode to make more adjustments and once your done writing track automation you can set the tracks to "Read" mode and it will just follow what you have written.
Or you can make an aux track... route all the VI tracks to the aux... set the aux to write automation and use the buss to adjust the volume of them all in one track (less automation nodes but also takes away voices, so this is where you can choose how you want to do it).
http://www.youtube.com/watch?v=ge_Dqspmwlo
http://www.youtube.com/watch?v=Oj-hE2fXoTo
Last edited by jasonthurley; 03-21-2013 at 11:12 AM. Reason: Forgot to paste the 2nd video
Old 03-21-2013, 07:46 PM
elicious elicious is offline
i think he's trying to use one mod wheel to midi volume automate all 4 trax with one pass.
if so, set all 4 trax to receive midi on the same channel.
(they've prolly defaulted to diff ch's)
i do it from the instrument view.
then, save those trax as a preset for further use
b.o.l.
e
ihatetyping
Old 03-22-2013, 07:02 AM
mickelini's Avatar
mickelini mickelini is offline
Shift-Click each additional record enable button.
Old 03-22-2013, 01:29 PM
Thanks. It worked.
Old 03-23-2013, 07:12 AM
mickelini's Avatar
You're welcome.
Turn off Auto Record Enable Clicked Instrument Track? DrFord macOS 16 04-04-2023 05:47 AM
Record Enable Tracks chuckgreenjr Pro Tools 10 6 05-31-2012 08:33 AM
Comping multiple tracks that are in a group problem no-xplode macOS 1 01-25-2012 02:09 AM
Record enable instrument tracks in midi editor Intransit Pro Tools TDM Systems (Mac) 8 09-22-2011 02:20 PM
How To Enable Record On multiple tracks jdsmooth615 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-05-2010 10:35 AM
