Old 05-11-2012, 07:02 AM
BigMacBoy BigMacBoy is offline
Default New Pro Tools 9.0 install and "Engine.dpm" won't load
Hello,
I installed my first Avid Pro Tools software yesterday, Pro Tools 9.0 and I thought everything went fine. When I try to instantiate the program is starts loading plug-ins and hangs when it reaches the "Engine.dpm" file.
I ran the Pro Tools 10 update program and it still does the same thing. I've used Digital Performer for years and it loads just fine.
I would appreciate any assistance in resolving this issue.
BMB
Old 05-11-2012, 01:35 PM
Talking Re: New Pro Tools 9.0 install and "Engine.dpm" won't load
Just to bring this thread to a close, I fixed the problem. I removed the "Engine.dpm" files and everything is working it appears. Now I just have to learn how to use the program!!!
The offending file was evidently from a program that I demo'd so all is well. Sorry for any trouble but I'm running PT10 now so I'm off to play.
BMB
Old 05-11-2012, 02:05 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: New Pro Tools 9.0 install and "Engine.dpm" won't load
Take it slow and easy. Do a lot of reading and a lot of watching. Then when you jump in you will be like OH YEAH! Most programs are about the same. Just different HUI.
If you want everything in one. This is where I get a lot of tips and tricks. Russ is a great teacher.
http://www.airusersblog.com/
Good luck BIGMACBOY.
Pro Tools 11 stuck on "Initializing Audio Engine" AudioDrummerGuy Pro Tools 11 10 01-19-2014 12:47 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
pro tools 8 stuck at "structure" at initial load Awesomeworld General Discussion 8 09-21-2011 01:10 PM
"Unable to load class:"TPopup" Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-01-2010 05:47 AM
PT 8 LE wont load after install --> stops at "DAE Loaded" jmasengarb88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-20-2009 07:27 PM
