Can't record audio. Track meter not moving
Hi guys,
I'm brand new to Protools and I was going through the tutorial in the manual and I'm stuck on the 'record your performance to a track' section. I do exactly as it says, but the track meter doesn't move when i make noise into my microphone. i'm pretty sure I have set up I/O correctly (I have my mic plugged into input 1 of my audio interface and i'm pretty sure that's what i have selected, picture of my settings is here http://img819.imageshack.us/img819/9...10831at194.png). I can hear the sounds from my mic through the monitor speakers and i can see the track meter moving on the M-Audio Profire control panel, but absolutely nothing on the track meter on Protools. I have tried reinstalling both protools and the profire drivers to no avail. Can anyone help me out? Cheers! |
Re: Can't record audio. Track meter not moving
track>> input monitoring
options>> pre-fader metering try both
www.dominicdotokune.com |
Hello ausnick on'eim...
We have to ask the obvious somtimes, but u do have the track armed in record mode correct?..
Cheers for the quick responses guys!
i've selected input only monitoring and pre-fader meeting has also been already selected. And yeah I am pressing the red record button whilst i talk into the mic :-/ |
hope that makes sense....
"Sometimes having limits keeps you sane"- Albee1952 |
Are you using a Mic that requires phantom power?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Well, if im just trying to set my levels, surely i don't need to press the record button on the Transport? Regardless, I tried it and the track meter on the mixer still won't budge.
I'm using a Samson Q7 snare drum mic, which as far as i'm aware, shouldn't need phantom power (only the ambient mics need phantom power i think). I am hearing it loud and clear on the monitor speakers, presumably i wouldn't if it required phantom power? |
Can you post a screen shot of your Mix and Edit window so I can give you a better solution???
Instead of asking you 1 million questions.... LOL
No problem at all!
Mix window: http://img192.imageshack.us/img192/2...10902at174.png Edit window: http://img11.imageshack.us/img11/262...10902at174.png Cheers! |
Unable to Record (digitize) a Regular Midi Track to an Audio Track | JuicyMusic | macOS | 9 | 02-27-2013 08:52 AM |
Audio Track Meter is peaking | BiggiT | macOS | 2 | 04-09-2011 01:36 PM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
moving audio only up to another track | beatz_crazy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-11-2005 01:23 PM |
Midi track meter dead,record enabled,data recordin | coryc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-19-2004 07:52 AM |
