Old 11-07-2010, 09:31 AM
futreboy futreboy is offline
Default Aux inserts not working on 8.0.4, but work on 8.0 and previous
Hello folks... I'm still having problems with external hardware devices, both via spdif and analog. If I create an AUX track and set it up it sends information to the device but does not receive it back. This happens on both SPDIF 17-18 as well as on say, analog7-8.
I'm using a Digi003Rack+ with a windows computer.
Yesterday I went through and removed PT8.0.4 and reinstalled PT7.4 and it worked fine. I then re-installed 8.0 and it still worked fine. Then when i did the 8.0.4 update, i lost the functionality once more. Has anyone had this same problem and found a solution?
THanks.
Old 11-07-2010, 01:56 PM
Default Re: Aux inserts not working on 8.0.4, but work on 8.0 and previous
Did you double-check your IO settings?
Old 11-08-2010, 07:35 AM
I've checked my IO settings numerous times. Re-configured them. Imported other people's IO settings that don't have the problem... I"m about out of ideas.
I don't know if it's related, but also occasionally after recording a track or two i take them off record and the tracks still allow input, giving me some nice screechy feedback when i least expect it... the inputs seem to get stuck on and not be able to shut off until I use that input channel on another track.
I might just have to roll back to 8.0... or 8.0.3 if i can find it to download.
Old 11-08-2010, 07:58 AM
If you are on XP, I would go to 8.0.1cs2.
Old 11-14-2010, 04:20 PM
Thanks for the suggestion. I'll try it out and hopefully it helps. I was thinking maybe a firmware problem, but I've got the latest of that as well.
I'll give this a shot!
Hardware Inserts not working goom Pro Tools TDM Systems (Mac) 9 10-30-2021 08:49 AM
Mbox 3 Pro inserts not working fallenidols macOS 6 12-20-2011 03:38 AM
does previous version of PT need to be installed for PT9 Crossgrade to work? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2011 07:44 AM
Someone Help Please?? How to pull previous work to Pro Tools?? djbjamz Pro Tools SE and Essential (Win) 0 06-15-2011 05:04 PM
Will Xpand work with previous versions? rlcowa@work2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-16-2006 08:15 PM
