Old 06-17-2010, 02:08 PM
Frank of Denmark Frank of Denmark is offline
Default Good LinMB setting for strings ?
Mixing and mastering a classical piece I recorded today with 30 strings (violin, viola, cello & bass). Real strings, not keyboard. It's high pitch romantic strings. And I just wondered if anyone out there had a good EQ setting for it ? I thought about using LinMB, L2 and a touch of Revibe.
Hope to get some suggestion, as I have to deliever a master tomorrow
Cheers
Old 06-17-2010, 02:59 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: Good LinMB setting for strings ?
OFF!
Seriously that's a sledgehammer when a small camel's hair brush is the appropriate tool.
I'd just use a touch of the best plate or hall reverb I had with all early reflections turned off. Depending on where it was recorded, you might need to roll off some traffic noise or HVAC rumble down below 50 Hz. but that should be about it for eq. unless there were big problems with the microphones.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 06-17-2010, 03:03 PM
Thanks, Bob. You're absolutely right. Good advice. I will do just that.
Cheers from Copenhagen
LA Scoring Strings vs Hollywood Strings Stig Eliassen Virtual Instruments 40 10-02-2011 02:13 PM
Good Strings? TwoEdgedSword Virtual Instruments 16 09-06-2011 09:21 AM
Cinematic Strings...... Good Buy? ed13adema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-26-2010 02:03 AM
Good strings pads artvolk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-08-2005 03:35 AM
OT: Guitar strings online...any good sites? Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-06-2004 12:02 AM
