Old 05-03-2010, 06:26 AM
teacherman teacherman is offline
Default PT 7.4.2 and PT 8.0.1 on same System Drive
Can PT 7.4.2 and PT 8.0.1 co-exists on the same system drive?
thanks
Old 05-03-2010, 09:04 AM
DigiTechSupt's Avatar
Default Re: PT 7.4.2 and PT 8.0.1 on same System Drive
No, they cannot. You would have to have 2 separate partitions with 2 separate OS installs - one for each Pro Tools version.
Avid Audio Tech Support
Support FAQ
Old 05-03-2010, 11:26 AM
thanks DIGITECHSupport,
That's the info that I needed to know.
Old 05-03-2010, 05:54 PM
Craig F Craig F is offline
and reFIT works well if you don't want to hold the OPTION key down
Thank you,
Craig
Old 05-03-2010, 06:03 PM
Thanks Craig.... I'll check into that.
Later,
Old 06-15-2010, 01:59 PM
alexeymohr alexeymohr is offline
I just wrote a post about this exact issue on my blog:
http://www.protoolsisawesome.com
While you can't install them both on the same partition, you CAN make multiple partitions on the same physical hard drive and then do multiple installations. Highly recommended.
- Alexey Mohr
https://www.parkstreetpost.com
No Audio, But Just Samples. System Drive Or Seperate Drive. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-10-2010 03:47 PM
System Drive and Audio Drive Question. philip888 Pro Tools M-Powered (Win) 2 06-03-2009 11:30 PM
Audio drive plus system drive, where Structure? Blustar Virtual Instruments 3 09-17-2008 04:01 PM
scsi ultra160 disk for system drive and audio drive jazzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2001 06:54 AM
anyone using the system drive and storage audio drive in the same SCSI chain? riorecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2000 11:09 PM
