Old 08-02-2009, 11:04 PM
nz nz is offline
Default Moving all regions and tempo/meter info at same time
Hello,
I'm not a newbie, but I have a question regarding moving regions in a song in PTLE8.
I am needing to move a bunch of regions forward in the session and when I do I want to take the tempo and meter changes along with them. Right now, if I move a region, the tempo/meter info remains.
Is there a command where I can move both at the same time?
Thanks!
nz
Old 08-03-2009, 01:14 AM
flommer flommer is offline
Default Re: Moving all regions and tempo/meter info at same time
Not sure exactly how you are moving these regions, but there a couple different possibilities
In Event>Time Operations you have the choice of Insert time or Cut time
Also, if enable the "all" group in the edit window, it should move all the ruler stuff with your selection
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-03-2009, 02:58 AM
elicious elicious is offline
what you need to do is first make sure that the properties you want (tempo, meter, markers, whatever) are showing in the ruler.
then after you've made your selection in the timeline
shift clic in each of the appropriate rulers and they will follow along.
b.o.l.
e
ihatetyping
Old 08-03-2009, 05:55 AM
nz nz is offline
The only problem I have when I do that is I get this message:
This operation is not currently supported for Conductor rulers. Use Cut/Copy/Paste/Clear instead. Continue operation without the conductor rulers?
So if I continue then I move the regions without moving the tempo automation. If I turn off the conductor then I lose the tempo information.
Am I missing something?
Any thoughts?
nz
Old 08-03-2009, 05:58 AM
nz nz is offline
...and markers...
nz
Old 08-03-2009, 05:49 PM
Try 'Insert Time'.
filosofem
Old 10-25-2009, 02:18 PM
nz nz is offline
Help!
It can't really be this hard!
I am merely trying to select a region along with the tempo and move it to a different location. Insert time is not what I need and when I turn the conductor track off I lose all tempo information.
I select the region and then shift/click the tempo track and when I go to drag it give me the above information.
I just want to be able to drag regions around and have the tempo info follow it.
Is it even possible to drag the regions and have the tempo follow?
Thanks so much.
Does anyone know how to do this?
nz
Old 10-25-2009, 03:18 PM
Copy and Paste including Rulers is the only way other than Insert Time.
filosofem
Old 07-08-2010, 07:32 PM
Mixer31 Mixer31 is offline
I have the same problem - no way of moving all the audio and the tempo conductor tracks together - I get the exact same result as NZ.
This particular piece of music has around 30 tracks of audio and midi and tempo changes and I need to move to a new location.
Much appreciated if any shed light on this.
Cheers
Old 01-27-2012, 06:04 PM
dogsbody dogsbody is offline
I wanted to make a copy of audio with tempo changes within the same project (ie to have an original version next to one I could mess with)... Had real trouble trying to copy tempo AND audio....
SOLUTION:
- highlight the audio I wanted copied (with a bit of blank space either side)
- shift/click the tempo marker bar
- 'Duplicate' (Command D)
Strange that shift/click on the tempo bar with a straight copy and paste doesn't seem to work... It'd be nice if this process could be made far more intuitive...
Cheers
Tim
"Pinning" the tempo ruler / keeping regions in time when moving geelo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-17-2016 11:08 AM
Why does tempo & meter info not move when shuffling ? smpkeys Pro Tools 9 9 03-21-2011 12:45 PM
Altering time signature/meter of one bar ruins the rest of my tempo map Robes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-19-2010 06:55 AM
Pro Tools request #2: Lock MIDI tempo/meter info to timeline maxx Pro Tools TDM Systems (Mac) 6 06-17-2002 09:51 PM
Midi request: Lock midi regions/meter/tempo to timeline maxx MIDI 1 06-12-2002 11:13 AM
