Old 12-02-2008, 09:16 PM
Jared_TL Jared_TL is offline
Default Structure - what does "Monolithic" mean as it pertains to "part" files?
Greetings,
I am saving my parts with the Monolithic radio button checked. My assumption was that it saved the samples in some proprietary container so that the part always has its files, not just pointers to files in another directory. Is this what is supposed to happen? I note that a part file saved as monolithic can get sizable - and it seems to be related to the size of the samples. Am I understanding this right?
Ok, so why, when I load up the session and pull up a patch with four of my parts (all saved as monolithic), does structure report that it can't find the sample files??????? [btw, the original files were in fact moved to a different location] Aren't they embedded in the part file???? Am I missing something fundamental or is this a bug?
I have noticed quite a few bugs in Structure - a few that actually kill PT and require a reboot. Very cool software - I sure hope they release at least a bug fix revision.
Thanks,
Jared
Old 12-03-2008, 12:15 AM
RussUK RussUK is offline
Default Re: Structure - what does "Monolithic" mean as it pertains to "part" files?
Yes it means a BIG patch. There's a handy FAQ for structure here
http://www.digidesign.com/index.cfm?...id=34&eid=4443
And also an AIR User Blog here
http://airvirtualinstruments.blogspot.com/
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 12-07-2008, 03:37 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I'v had problems when i update a patch and overwrite it.
I get a error message and it destroys my patch.
Maby this is your problem too ?
Two Files "L" and "R" when bouncing to disk? TruestPain Tips & Tricks 13 02-15-2016 08:51 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
PT 8.1 audio "hits" or "pops" when i open files from PT7... djoeyd77 Pro Tools TDM Systems (Mac) 1 10-31-2009 03:59 AM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
