Old 11-18-2008, 11:20 AM
spiritG spiritG is offline
Default Efficient means of auditioning multiple takes/playlists?
In Digital Performer there is a trick that can allow one to listen to take after take without having to disturb one's concentration or the writing of notes by doing a manual command to switch takes. One uses the "advance take" function (track has to be left in record) of the programmable "command bindings", and adds a midi track to send the "advance take" command. This results in each pass in loop playback switching to the next take- very helpful if there are 100 takes of a difficult two bar passage one needs to evaluate.
Is there any better way in ProTools than having to drag an audio region manually from the bin each time to switch takes on listenback (after having done loop record for a high number of passes)?
Also in PT if one loop records 10 passes of the 2 bar passage, then stops, then does another 9 passes, then stops and does another 12 before listening back to every pass, it can get difficult to keep track of which pass is which in the audio bin. (In DP loop record advances and individual tracks "takes" by 1 for each pass of the loop and places the audio region there so you don't have to keep track of which playlist Vox 1.07.8 is).Any suggestions regarding this problem would be welcome as well.
Thanks in advance
Old 11-18-2008, 11:25 AM
elicious elicious is offline
Default Re: Efficient means of auditioning multiple takes/playlists?
cmd-clic on the region to get a drop down of different takes to audition.
b.o.l.
e
ihatetyping
Old 11-18-2008, 11:34 AM
flommer flommer is offline
PT8 has a new comping feature that should make this even more user friendly. Not too long before it should be available..
Check out the video on DTV in the ProTools 8 info section..
http://www.digidesign.com/index.cfm?...99&langid=100&
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Importing multiple takes to one audio track creating playlists steveculp Pro Tools 10 2 02-17-2013 02:39 AM
Keeping on top of playlists, multiple takes markblasco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-14-2005 10:44 AM
Playlists, multiple takes - follow edits? MoreMeintheMonitors Tips & Tricks 1 04-24-2003 02:07 AM
Auditioning Takes simonftrent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-04-2001 02:25 PM
Auditioning Takes (PT5) Howardk Pro Tools TDM Systems (Mac) 0 06-14-2000 09:20 PM
