Old 03-19-2008, 04:08 PM
blastula blastula is offline
Default View Selected Region in Edit WIndow?
If I make a selection in the edit window, capture and name the region, and then later select that region in the region list, shouldn't the region become selected in the edit window? This isn't happening for me currently (HD 7.4cs2).
If I drag the region from the region list into the edit window from the region list, and then select it in the region list, the newly dragged occurence of the region will be selected but not the original occurence.
Is this correct behaviour?
Thanks,
Rob
Old 03-20-2008, 01:18 AM
tj_davies tj_davies is offline
Default Re: View Selected Region in Edit WIndow?
Maybe Command+Shift+D will help. This "display all regions"-command for the audio bin sorts the audio again. So maybe when doing this, Pro Tools understands the new name linked with the region on the track.
Just a guess.
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 03-20-2008, 05:16 AM
TCDet TCDet is offline
Preferences>edit> (select) "Edit Selection Follows Region List Selection".
Pro Tools 8 Problem All tracks are selected for everything in edit window. DONNX Pro Tools TDM Systems (Mac) 16 08-30-2021 04:31 AM
Key Command Edit Window Change Track Height All Selected? DFT Pro Tools 10 3 03-08-2013 02:20 AM
Edit window - everything selected bug still not fixed! Marsdy macOS 1 11-02-2012 10:48 AM
wherever i click in my edit window all tracks are selected stephendavis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2007 10:13 PM
How do you group selected objects in the edit window ? kenny j 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-10-2001 12:01 AM
