Old 08-18-2007, 09:32 AM
ashley27 ashley27 is offline
Default converting a logic 7 session in to a PT7 session
what is the quickest and most relaibel method of doing this please? thanks
Old 08-19-2007, 12:08 AM
mix109 mix109 is offline
Default Re: converting a logic 7 session in to a PT7 session
Export your Logic Session as OMF-if you have the DigiTranslator option in ProTools- that is the only way of 'conversion'
Otherwise,export the files from Logic from Start to End then import them ino ProTools
Old 08-19-2007, 03:27 PM
AKA AKA is offline
in Logic - export each track. from session begining to end, and import to PT.
I do it on a daily base. and that seems to work best for me.
make sure you leave enough headroom on your master fader.
DesignInSound
Old 08-23-2007, 01:54 PM
another question on this actually. i did it the other day and have of the sessions were fine.
But within half of them there is a mix of both 16bit and 24bit samples. What is the quickest way of merging all of the files together so they all have a 0 start time?
In the end i went in to prefs and under audio - DAE, changed the overall sessions bit rate as necessary.
Get the feeling that there would be a much quicker and more PC way of doing this.
My logic knowledge is poor.
Converting 44.1 session to 96 d.f. Pro Tools TDM Systems (Mac) 3 05-03-2009 10:38 AM
Up-converting whole session? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-24-2009 12:35 AM
Converting 96K session to 84K ? TDMnovice Pro Tools TDM Systems (Mac) 1 03-16-2004 01:15 AM
Converting 44.1k session to 96k? generator Pro Tools TDM Systems (Mac) 1 06-18-2002 12:35 AM
Converting a PC LE session into 5.1 Mac TDM? popps Pro Tools TDM Systems (Mac) 1 05-05-2002 01:11 AM
