Old 04-11-2007, 05:17 PM
stephendavis stephendavis is offline
Default wherever i click in my edit window all tracks are selected
iMac, 2.16 Intel Core 2 Duo, OS X 10.4.9, Mbox, Pro Tools LE 7.3.1
in my edit window, no matter where i click, i cannot select a single track. whenever i click anywhere, it selects every single track.
my mouse is setup correctly, and the tracks are not grouped. this has to be a simple setting that i have configued wrong. has anyone else had this issue? help!
Old 04-11-2007, 05:42 PM
blackmacdaddy blackmacdaddy is offline
Default Re: wherever i click in my edit window all tracks are select
Is the ALL! group lit up and you have the Grabber tool, or are using the Smart Tool in the bottom half of the track so that the Grabber appears?
If you Command = to the MIX window and hit Shift ! the ALL group (created by default in every session) will be deselected.
OR Click the << to see the Groups list and click one time with the mouse on the ALL group. Does that get it?
It's only R'n'R but I like it.
Old 04-12-2007, 10:13 PM
yes! all i had to do was hit shift! in the mix window and that solved it! thank you so much. what a pain in the @$$ that was!
Pro Tools 8 Problem All tracks are selected for everything in edit window. DONNX Pro Tools TDM Systems (Mac) 16 08-30-2021 04:31 AM
Key Command Edit Window Change Track Height All Selected? DFT Pro Tools 10 3 03-08-2013 02:20 AM
Edit window - everything selected bug still not fixed! Marsdy macOS 1 11-02-2012 10:48 AM
View Selected Region in Edit WIndow? blastula Pro Tools TDM Systems (Mac) 2 03-20-2008 05:16 AM
How do you group selected objects in the edit window ? kenny j 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-10-2001 12:01 AM
