Old 05-05-2005, 12:11 PM
InjuredEar InjuredEar is offline
Default 6.9 and \"Auto Join\" grayed out?
I'm experimenting with my Command-8 and version 6.9
In the Automation Enable window (command 5) the "auto join" button is grayed out.
How do I "un-gray" it?
According to the "What's New In Protools 6.9" file you can select individual tracks to auto-match when in auto-latch.
However the directions for selecting all tracks and selecting an individual track are the same:
Quote from "What's new in Protools 6.9.pdf":
AutoMatch Function
During playback, you can stop writing of automation
on Write-enabled or Latch-enabled
tracks and return automation to previously written
levels by ramping up or down according to
the AutoMatch time.
To end an automation pass on a single Write- or
Latch-enabled track with AutoMatch:
? During playback, at the point where you want
to stop writing automation on a track, hold
Ctrl/Clutch and press the F4 switch on the
channel.
The track stops writing automation and ramps
back to the previous automation level. The
length of the automation ramp is determined by
the AutoMatch Time preference.
To end an automation pass on all tracks with
AutoMatch:
to stop writing automation, hold Alt
+Ctrl/Clutch (Windows) or Option+Ctrl/Clutch
(Macintosh) and press the F4 switch on a Write-
or Latch-enabled channel.
end quote
What is the F4 switch on the channel and how is it different from the f4.Fader Mute switch on the righthand side of the Command-8?
Greg
Old 05-15-2005, 05:16 PM
Default Re: 6.9 and \"Auto Join\" grayed out?
so maybe I just said too many words in that post and didn't make enough sense
Is Auto-Join only available to users of the more expensive Digidesign control surfaces?
Old 05-16-2005, 07:03 AM
clusterer clusterer is offline
good question!
I´m also interessted to know if this function is availible for command8!
DIGI???????????
thx!
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 05-17-2005, 09:26 AM
DigiTechSupt's Avatar
This feature is only available on the ProControl and Control|24.
Avid Audio Tech Support
Support FAQ
Old 05-17-2005, 11:00 AM
Dang.
Thanks for the clarificiation.
So for the second part of my question that was so poorly worded at the top:
Is it possible to have several channels writing automation in auto-latch and just automatch one?
The instructions as best as I have tried to follow only allow you to drop all automation writing/updating tracks simultaneously.
Thanks,
Greg
Old 05-21-2005, 07:15 AM
deafguy deafguy is offline
Why would you exclude a feature for a current product but include it for a discontinued one?
Is the Command 8 now excluded from software updates?
I'd like to know.
the Computer: MBP M2 Max
the ProTools: PT Studio | MH UNL-8 | Grace m905 | Artist Control
the Rest: Amps | UA OX | V72 | Shelford Channel
Old 06-07-2005, 12:57 AM
Upon further review,
Why?
Why not have auto-join available for people who are mixing completely independant of a control surface?
Even if you're just mouse-mixing, why shouldn't you be able to use auto-join?
Greg
glitch with auto join in PT 10 mixify Pro Tools 10 3 06-25-2013 02:18 PM
Auto Join Inconsistency midnightsun ICON & C|24 4 01-25-2009 01:32 PM
Auto Join and Trim mode thermisonic Post - Surround - Video 2 01-15-2009 08:36 AM
What does the "Auto Join" tab do? abbyin3d Pro Tools TDM Systems (Mac) 4 01-18-2006 07:39 AM
