Old 03-22-2002, 07:58 PM
Boom Chic Boom Chic is offline
Default Dolby Warble tone?? Anyone?
Delivery specs for a project asked for Dolby Warble tone. What is this, how can I generate it, and what the heck is it used for?
Thanks.
Karen Basset
Boom Chic Studios
Los Angeles, CA 90048
[email protected]
http://www.boomchic.com
Old 03-22-2002, 08:04 PM
The Chinese The Chinese is offline
Default Re: Dolby Warble tone?? Anyone?
Dolny Warble tone means a Dolby "A" type noise reduction is being used. It is a 1khz tone that "Warbles a bit" However, I suspect that your client may mean Dolby SR...
You might want to check with your client. As for creation, any Dolby 361 or 363 w/ a Dolby A card will create it
Old 03-22-2002, 08:08 PM
I am going totally digital, is this necessary?
Karen Basset
Boom Chic Studios
[email protected]
Old 03-22-2002, 10:45 PM
zoundsabar zoundsabar is offline
The key thing about the Dolby "warble" tone is that it is at "Dolby Level" which is 50% modulation of the optical track area, if my memory serves me right. It is the equivalent of X (can't remember) dB below max level so that when the optical track is exposed it doesn't go into horrible overload distortion or "clash". Check with Dolby's web site to ensure correct level. The actual warble is optional, but the level is critical.
Old 03-24-2002, 11:35 PM
Tiago Silva Tiago Silva is offline
If the producer is going to make exhibition copies in film, you're never going to be completely digital. Even if you're making a DTS mix, I believe no producer will print a DTS only copy. They'll always make a Dolby SR-D copy and then add the timecode track for DTS.
And Dolby SR-D, like the name implies, always has the Dolby Digital data between the perfs and also the analog optical tracks, for compatibility of the copy with the largest number of theatres possible, and to prevent sound dropouts in case the digital information is obliterated. In the latter case, the decoder will 'panic switch' into the analog Dolby SR track.
A job's not done until it's ready, or the producer is breaking down the studio's door...
HTML code is On
D-Verb warble scottgreiner AAX Plug-ins 18 09-09-2019 08:46 AM
is there a way to get rid of elastic audio warble sound. evilstudios Pro Tools 11 10 12-23-2013 10:28 AM
Pro Tools 10.1.2 Elastic Audio Warble rogercollege Pro Tools 10 8 12-02-2012 05:41 PM
Test Tone Audio File or Tone Generator Imagine Pro Tools TDM Systems (Mac) 4 04-15-2005 06:28 AM
High Frequeccy Warble Sound? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-03-2001 08:03 PM
