Old 02-18-2014, 07:11 PM
djkikis djkikis is offline
Default 192 I/O doesn't work with PT 11 HD
Hey guys,
I'm using a:
- 192 I/O
- PT 11 HD
- Native HD PCIe Card
- Mac Pro
I've already got the license for PT11HD and PT10 HD. Thing is my Mac won't recognize the 192 I/O, neither does the Pro Tools. WHAT THE HELL AM I DOING WRONG!! any advice is much appreciated..
Old 02-18-2014, 07:28 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Default Re: 192 I/O doesn't work with PT 11 HD
On start of Pro Tools ie: the splash screen, click and hold the "N" key until a message pops up about choosing the playback engine.
I tend to chew gum and rub my tummy at the same time as this sometimes helps.
http://avid.force.com/pkb/articles/e...oting/en381131
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 02-19-2014, 04:41 AM
Drew Mazurek's Avatar
Originally Posted by djkikis View Post
I've already got the license for PT11 and PT10 HD.
Double checking that you have PT11HD. It's in the title of thread but not here.
www.drewmazurek.com
Old 02-19-2014, 07:50 AM
I've done that already and the only choice I have for a playback engine is 'ProTools Aggregate I/O' which only has 2 inputs, and 4 outputs (clearly not the 192 I/O)
Also my Avid CoreAudio Manager doesn't detect the 192 I/O i.e.
Avid HW: "Unsupported Device"
Status: Not Connected (HW not found)
Trying to look for a specific driver for the 192 I/O but can't find it. I bought it 2nd hand from vintageking.com
So how.. what do i do………………………….
Old 02-19-2014, 08:07 AM
feliponk's Avatar
feliponk feliponk is offline
Return it....
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 02-19-2014, 08:18 AM
Still not clear if you are trying this with PTHD11 or PT11?
It matters.
A regular PT license will not see any HD cards or interfaces.
www.drewmazurek.com
Old 02-19-2014, 08:35 AM
feliponk's Avatar
It matters.
He said...
- PT 11 HD
So it's HD.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
Old 02-19-2014, 08:42 AM
Southsidemusic's Avatar
Have you tried to swap the digilink cable on the back to the second connector
and see if that works!? Also try to put the PCIe card in a different slot in the computer and see if that works, and we also had to do a PRAM purge 2 times to make our old macpro 3.1 see the pcie card when we had native card before our HDX cards. I will update our Sig as soon as possible
Best Of Luck
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-19-2014, 08:48 AM
Originally Posted by feliponk View Post
He said...
- PT 11 HD
So it's HD.
Cool, he now edited his post to remove the ambiguity.
www.drewmazurek.com
Old 02-19-2014, 09:06 AM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Reboot
Run Digitest
Update firmware
I had to do this to mine before I could use it
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
The plugs that WORK and DON'T WORK on 7.0 The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-10-2006 10:12 PM
New Mic won't work DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2002 09:06 AM
How does Direct Connect work?? (Does it work well??) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-18-2001 08:13 AM
