Old 12-30-2009, 04:18 PM
tmanoff tmanoff is offline
Default Kontact/Garrittan from Sibelius into Pro Tools?
I can't figure this setup. I can get Sibelius (with its normal sounds) to play in Pro Tools by choosing Sibelius as an Instrument. I can get the Garrittan Orchestra to play as an midi instrument by choosing the Kontack Player as an insert.
But what is the setup to have a Sibelius Orchestra score play in Pro Tools with the Garrittan Orchestra?
Old 01-02-2010, 04:09 PM
gdugan gdugan is offline
Default Re: Kontact/Garrittan from Sibelius into Pro Tools?
I don't use GPO (the Vienna Instruments Special Edition ($500) is WAY better), and I'm not exactly sure what you're asking, but maybe this will help.
In Sibelius, go to Play>Playback Devices. Choose Kontakt Player 2 from the "available devices" and load in GPO. I believe the Sibelius score will then be played back using GPO samples, and the audio will be routed into Pro Tools.
Sibelius Tech-->Sibelius 6.2 Will NOT work on the Same Lion Machine as PT 9.0.5?!?!! humdrumprune macOS 4 11-04-2011 06:36 PM
send to sibelius, export to sibelius... ericlees Pro Tools M-Powered (Mac) 1 11-07-2010 08:02 PM
Pro Tools 6.9 + Kontact?? hed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-12-2005 01:25 PM
Kontact 2 with Pro Tools Shutting down jeroddumas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-29-2005 05:39 AM
Kontact Player & Sibelius w/002 tbuttons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2005 08:09 PM
