MIDI Keeps Repeating Notes
Can anybody see what I am doing wrong? I have a very simple setup - just a PC with 24 GB ram with it's sound card - no interface, no mic input. I connect the PC Sound Card's Line Out to an amplifier to listen. I am simply trying to play an Xpand2! bass, piano or organ using the midi editor piano keyboard. For example the default "Blues" Template provides a MIDI Track for a bass part to be recorded. So I select the Xpand2! plugin and choose a bass sound. I "record enable" the track. I open the MIDI Editor to check what it sounds like. However every time a press a key on the soft key board, I get multiple repeat notes like there is delay plugin somewhere (which there is not). The repeats seem to go on for ever as long as I press the key. I have disabled all effects on Xpand2! as far as I can see. This makes me think there is some sort of a feedback loop somewhere where the track's output is being fed back into the input. It seems to go away if I put Pro Tools into "play" ( i.e. play a track). I can then hear each note perfectly without repeats. (That sort makes sense because in play mode there would be no input to feed back into - which reinforces my idea of an unwanted feed back loop. I was expecting to be able to select a sound from Xpand2! and just play it and hear it through my amp. Anybody Help Please? |
Midi notes deleting when editing and writing in notes | SeventhSounding | MIDI | 5 | 01-14-2018 02:34 AM |
Stop MIDI notes from overwriting other MIDI Notes? | tjs5200 | Virtual Instruments | 4 | 06-16-2017 04:01 PM |
Kick drum MIDI in Xpand suddenly repeating rapidly! | ThereAreGoats | Pro Tools 11 | 2 | 01-02-2015 11:14 AM |
Repeating Notes | wgouldsby | Pro Tools M-Powered (Mac) | 0 | 06-19-2011 05:02 AM |
Recording Midi notes and keeping existing notes during record | Sherbert99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-15-2008 09:40 AM |
