Old 09-11-2006, 12:15 PM
porkipine porkipine is offline
Default Compression threshold level?
I'm am wondering about the actual level that registers when inserting a compressor plug-in on an channel insert vs the master, stereo channel.
The threshold starts to register as low as -31 or so when inserting it as a channel insert. Is this low level just a reflection of the signal strength at that point in the system? When mixing to a nominal level of -12db on the output, I would expect to see threshold levels much higher. So if I insert a compressor in the final outs, I would expect to see a threshold of let's say -15 or so if I'm attempting to maintain a 3:1 ratio peaking at -12.
does any of this make sense?
Old 09-11-2006, 01:09 PM
Matt Rouch Matt Rouch is offline
Default Re: Compression threshold level?
I think you might have some misconceptions about how compression works.
Try reading this.
mindnoise mindnoise is offline
HI,
when the threshold of a comp registeres is heavily dependend on its attack and release times.
if you want to measure peaks set in the prefs "peak level hold" to infinite and
apple+click into the Volume window right below your track faders.
regs the www.pspaudioware.com has a good set of analog meters. digi also has its free BF Meters
an RND digital has the Inspector for analysing levels.
jk from http://www.sonoria.pl/jk/index.html has also some good tools for this and more.
personally I would not use a comp to measure levels.
regs
last: PT11.3.1
Old 09-11-2006, 02:13 PM
thx for the referral. Interesting reading.
Actually I do understand how a compressor works. My question was related to the meter readings that show when your doing channel insert vs master channel insert. I think it has to do with the gain structure of the signal at the channel input point vs the final output. I made note that the actually meter readings on the plug-in where showing signal at the -31 or so level and it initially confused me. I think what I'm looking at though is just a -31 level at the point of compressor plug-in and the input meter on the plug-in is just telling me that. If I inserted the plug-in at the final output stage (master fader), it stands to reason that the input level will be much higher. I was looking for confirmation of this point.
thx
Tab to Transient threshold oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-16-2009 04:18 AM
Compressor & Threshold Johnny Cadelco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-18-2006 10:13 PM
Broadcast level, compression, loudness... TheMixShop Pro Tools TDM Systems (Mac) 2 04-01-2004 10:50 PM
Vocal Compression Level? CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-21-2004 09:38 PM
Level for Bouncing, Using Compression Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-24-2003 10:04 AM
