Latency recording stems
I'm noticing approximately a 980 sample lag in the stereo files I'm recording in a session. I've got delay compensation on, and I'm not seeing any numbers in red in the delay compensation panels under the tracks in the mix window.
Hardware buffer size is set to the max, 1024 samples. I've trashed the prefs. The files are bus stems from a mix. 48k, 24-bit. If I record a stereo file in a new session with no plug-ins, recording a track from audio playing on another track (either directly from a send or via a bus) there's no latency at all. Has anyone got any ideas about this? It's a pain as I'm having to trim the files before delivering them. Thanks. --- MacBook Pro (Retina, 15-inch, Mid 2015) Processor 2.8 Ghz Intel Core i7 Memory 16 GB 1600 MHz DDR3 Graphics Intel Iris Pro 1536 MB Mac OS Sierra 10.12.2 Pro Tools 12.7.1 Blackmagic Ultrastudio Mini Monitor (Thunderbolt 2) Avid Artist Mix (Thunderbolt 2 > Ethernet cable) Nugen Loudness iZotope RX6 |
Re: Latency recording stems
Could there be plugins on the bus stems .. not sure exactly how you are routing to your bus stems .. can you be more specific please !!
Thanks - I'm using a lot of plug-ins both on audio tracks and on aux busses. The stems get recorded from via their respective mix busses to further 'thru' busses (that have the same limiters as on the master output busses), then to audio tracks which record the stems themselves. The audio tracks that record the stems are free of any plug-ins. Hope this is understandable. I was under the impression delay compensation took care of all this! |
Master Faders' Inserts are not compensated for by ADC FYI. Always been this way.
In case it applies here. I haven't read everything in detail, just throwing this out there as a reminder. |
This is probably your fix. Hope it helps!
https://www.youtube.com/watch?v=xRIxvpdZ5Rs Rob Burrell aka mixboy
http://www.robburrell.com PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA |
Thanks Drew, but I'm not using Master Fader tracks at all.
Recording Stems confused | bryced87 | Getting Started | 4 | 11-05-2013 11:04 AM |
Recording Stems Simultaneously | sfreiman | Post - Surround - Video | 4 | 12-01-2010 09:38 AM |
Work Around: Re-recording stems while layingback to SR Deck | Karl Kalbaugh | Post - Surround - Video | 9 | 12-10-2008 01:26 PM |
re-recording stems & bus latency | bignick | Pro Tools TDM Systems (Mac) | 0 | 10-10-2006 08:10 PM |
Recording Stems into Pro Tools | filmixer | Post - Surround - Video | 13 | 08-16-2004 06:56 PM |
