Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 09-06-2017, 04:36 AM
Steven1145 Steven1145 is offline
Default S5 Joystick module calibration
Hey all, we just had a bad power cut here and on reboot one of the two joysticks on my CM 403 has lost its position calibration and and the dot does not follow the Joystick position anymore (stays stuck at the rear it seems).
Anyone know if there is a calibration procedure for the Joystick, or should I consider it dead?
Sent from my Galaxy S7
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 09-07-2017, 12:52 PM
DaveMagleby's Avatar
DaveMagleby DaveMagleby is offline
Default Re: S5 Joystick module calibration
To enter Test Mode press the 4 large switches simultaneously.
Pan L/R
Srnd F/B
Link
Solo
In Test Mode;
Channel Select switch exits any test.
Active sw. will enter LED tests
Motor sw. will enter switch tests.
Sel sw (third small switch down) followed by the Active sw. will re-calibrate to joystick.
Wave sw (fourth small switch) enters the joystick movement test.
Once here the Div and > switches will motor the j/s all left and all right.
The Foc and down arrow will step the motor left/right.
The other 4 small switches on the side do the same, but up/down instead of left/right.
Old 09-07-2017, 02:38 PM
Thanks Dave, I'll give that a try tomorrow morning.
Cheers.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 09-08-2017, 01:47 AM
So I tested the Joystick in test mode, and it reacts perfectly. However, once back in normal use it behaves erratically, forcing the dot to the rear/right even if I'm holding it at the front/left position.
Super weird.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 09-18-2017, 10:11 PM
So yesterday I replaced the Joystick panel with a spare I had, and I got the same behavior.
I decided to cold boot the two CM408 that they are plugged into and hey presto, problem solved.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Joystick S5-MC Gregor B. System 5 7 03-23-2017 09:39 AM
Joystick rcutz Avid S4/S6 16 05-01-2015 09:44 AM
Joystick recommendations? Eric R. Fischer Post - Surround - Video 10 06-20-2005 10:41 PM
Joystick for Mix system ripple FX Post - Surround - Video 4 01-04-2003 03:33 PM
Joystick option- cmaynes ProControl, Control|24, Command|8 0 08-11-2002 09:21 AM
