Old 05-29-2009, 06:18 AM
nicksorenson nicksorenson is offline
Default best drum trigger for EZDrummer, Reason, or Addictive Drums
Can anyone make a recommendation for a trigger for the above programs?
thanks!
Nick
Old 05-29-2009, 07:00 AM
Default Re: best drum trigger for EZDrummer, Reason, or Addictive Drums
what about triger-finger by M-Audio?
Probably hard to do rolls or snare grace notes with?
Old 05-29-2009, 08:30 AM
+1 for the M-Audio trigger finger. The beauty of this is; you have 5 pages of pad assignments so you can take one page and assign each drum to 2 pads. With 2 pads for each, doing two handed fills works very well. The only drawback is that getting the pads assigned is a one-time pain in the ***.(but once its done, its very cool). I also have a full Roland V-kit that I use a bit and many real drummers will play it with excellent results(I am NOT a real drummer). The main thing to remember(for non-drummers) is to try to think like a drummer and not program something that a human could not play.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 05-29-2009, 09:32 AM
reycantong reycantong is offline
I'm using a Roland V-Kit for Superior Drummer and EZ Drummer. So far, it's the best combo.
Old 05-29-2009, 10:15 AM
Would I be better off buying an Alesis DM5 or the Trigger Finger? I wonder if real sticks beating on the Alesis Electric Drum set as a trigger would sound better than tapping fingers on the Trigger Finger or other finger pad set?
Would I need more than this:
http://cgi.ebay.com/Alesis-DM5-PAD-S...3A1%7C294%3A50
to get rolling or would that connect right out of the box to a VI drum kit like Reason etc?
Old 05-29-2009, 01:53 PM
barstool719 barstool719 is offline
I use the AKAI MPD24 with BFD and Reason and love it. I'll build a custom NNXT kit with map the snares and toms to two pads each so that fills are a breeze.
I would love to move up to the Roland VKit one day. I hear the new Alesis kit is pretty good too.... real drum heads and real cymbals.
http://www.sweetwater.com/store/detail/USBProKit
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 05-29-2009, 04:35 PM
soundboy35 soundboy35 is offline
I would go with mesh heads if possible. I realize they're more expensive, but drummers will appreciate these for sure. I bought some mesh heads from Hart (who make them for the Roland V Drum kits) and they rule! I also use a Trigger Finger, as i'm not a drummer either, and it's great. Yes, a pain to program the first time, but way better than playing beats on a keyboard! Pretty cheap as well. The DM5 IMHO is outdated as far as the sounds and I noticed that the note length is not assignable either, so when you see the MIDI notes in PT they are tiny circles with X's in them! Sure you can go back and change the note durations in PT, but....
Anyone using the Alesis I/O MIDI thing?
http://drums-percussion.musiciansfri...ace?sku=449754
Mac Pro Dual 3GHz
10.8.5, PT10.3.9
MacBook Pro 15in, 2.3gHz,i7 Quad Core
10.12.6, PT12.8.
Old 05-29-2009, 04:49 PM
No difference in sound. It boils down to the person programming. Do you like to play like a drummer, or sit at your desk and knock out quick patterns. I do both depending on how much time I have(sitting at a kit takes me longer). As for using a Roland kit with real cymbals and hat, that's the best of both worlds right there.
Old 03-28-2010, 02:24 AM
DeyBwah DeyBwah is offline
I just got the Alesis Trigger IO and at first, was going to return it. It was not working well with Battery at all. Could not get the settings dialed in to get that "feel". Well, I changed my mind after installing the BFD Lite software that came with it. It's actually pretty good now! My triggers are also Alesis DM10 triggers so take that into account.
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts."
-Albert Einstein
Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub
Old 03-28-2010, 07:01 AM
Musicianista Musicianista is offline
KORG padKontrol.
Even if you have a pad kit to play, this thing comes in handy.
Excellent pads & dynamic control.
- Ando
003 / ADA8000
iMac 24 2.33ghz / 3gb Ram
OS X 10.6.2
Pro Tools LE 8.01CS1
DVTK2
LOGIC 9.1.1
Can't drag midi into midi/instrument track from os or ezdrummer/addictive drums NJ Soul macOS 7 05-28-2011 11:09 AM
addictive drums, drums replacement ericlees Tips & Tricks 2 09-28-2010 11:58 PM
Having a really weird problem with Reason and Addictive Drums... listenhard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-01-2009 03:37 AM
Transfering to Addictive Drums from EZDRUMMER automatic8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-26-2009 08:58 PM
Do I need a drum module to trigger drums or... s.d. finley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-14-2001 10:06 AM
