Old 03-29-2007, 10:35 AM
blankpro blankpro is offline
Default how do I open these files????
I got files from an apparently hostile producer that put all his files in an 'unsupported format'. When I first try to import them, Ptools says thay are not audio - when I get info, I see that they are called Lex Source or Rez Source (when they are in fetch). Barbabatch does not recognize them, nor does Jam.
I am runnig a MAC.
Is there a program I can buy or get that will make these audio files that I can use? Adding .wav does not make them usable (I know, duh, but I tried it).
Help, please!!! thanx...
javascript:void(0)
Old 04-04-2007, 04:33 AM
Pete Gates Pete Gates is online now
Default Re: how do I open these files????
Hi Bob,
I had a further look at the file you sent me. It looks like it's a headerless (RAW) 24 bit linear 1 channel 48KHz file (it could have been an SD2 originally, so May not have been intentionally done to scr*w you!). You can use something like Soundhack (or Cool Edit Pro or the estimable Rail's sd2toWav if you're on PC) to re-save it in a friendlier format. Good luck!
Pete
can you open PT 7.0 files in 6.9? schpilkas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-11-2007 03:35 AM
can you open PT 7.0 files in 6.9? schpilkas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-10-2007 01:51 PM
can't open files session files .....plz help... syntax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-19-2004 08:09 AM
Can't open help files sethmetal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-19-2003 10:51 AM
Open Files Post - Surround - Video 6 05-12-1999 01:16 AM
