Building a new system *feedback*
I am building a new (PC) based system to run digi002. I am concerned about *hardware compatiblity issues, so far I see none but if anyone cares to take the time to look over the following component list, and enlighten me to any conflicts that I may run into I would greatly appreciate it. Also, I am wondering just how important SCSI VS SATA is. I would like to be running a Raid 0+1 and hope that in some far off future DIGI gets cracking.Since that is not an option at present I will be using either a 160 gb SATA Drive or a 73GB SCSI Drive.
Motherboard: Gigabyte GA-8KNXP, Intel 875P chipset for Socket 478 P4 ATX motherboard Specifications: Supported CPU:Intel® Pentium® 4 processor. Hyper-Threading Ready Chipset:Intel® 875P MCH FSB:800 / 533 MHz FSB RAM:6x Dual Channel DDR 400/333 Max 4GB ECC Support IDE:2 x UDMA ATA 133/100/66 Bus Master IDE Max 4 Devices Slots:1 x AGP Pro, 5 x PCI (PCI 2.2 compliant) and 1 x DPS Ports:2xPS2,1xLPT,1xCOM,4xUSB,LAN and Audio Ports Onboard Audio:Realtek ALC655 CODEC Onboard LAN:82547EI Gigabit Ethernet Controller Onboard RAID:GigaRAID controller chip Onboard IEEE:Texas Instrument IEEE 1394 chip Onboard SATA:Silicon Image Serial ATA chip CPU: Intel Pentium 4 / 3.0CGHz 512k socket 478 Hyper Threading Technology 800 MHz FSB - RETAIL Specifications: CPU: 3.0GHz Type: Pentium 4 Northwood Cache: 512K BUS: 800 Mhz Socket: 478 (hyper threading will be turned off) Drives *still not certain whether I should be using SCSI or SATA so I will list both alternatives* Seagate 160GB 7200rpm SATA Hard Drive Barracuda 7200.7 ST3160023AS - OEM Specifications: Size: 160 Gigabytes Interface: Serial ATA Seek time: 9ms RPM:7200 Data Transfer: 150MB/sec Cache 8MB or if it really matters Cheetah 73LP Model Number:ST373405LW Capacity:73 GB Speed:10000 rpm Seek time:5.1 ms avg Interface:Ultra160 SCSI Ram X4 Dimms: CORSAIR MEMORY XMS Extreme Memory Speed Series, Low Latency (Twin Pack) 1GB(2 x 512MB) 2x(64MX64) PC-3200LL Specifications: Speed 400 MHz Organization 2 x 64M x 64 Memory type DDR Part number: TWINX1024-3200LL All the rest including power source and cooling solutions are a function of taste rather then being prime componentry for running pro tools, so I won't list those. The system I have selected is about as good as I will be able to get on my budget and the hardware has been selected to be compatible with itself, and I hope with pro-tools. If SCSI is going to be a prime issue then the Mobo I have in mind is the Gigabyte GA-8KNXP Ultra, essentially not much different just lacks the fire wire and has an added Onboard Adaptec Ultra320 SCSI chip. Thanks for any input you might have.
Answering my own questions since 1975 |
Re: Building a new system *feedback*
mmm,
reading that digi002 will not support Raid configurations.....erm, I get that right or I need some more coffee? Some more coffee didn't work. I don't quite understand why digi002 isn't compatible with using RAID array's. It seems obvious to me that using RAID 0, and raid 0+1 for the data concerned would boost write/read timings therefore maximizing system performance....
Building a system for PT PCIe HD1 system | Fullsound Recording | Pro Tools TDM Systems (Win) | 25 | 08-17-2008 03:38 AM |
Building A System | craigsbrain | Pro Tools TDM Systems (Mac) | 28 | 01-22-2006 09:08 PM |
Building my audio machine....feedback | jasonguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-30-2005 08:59 PM |
Help building a system...!! | Pro Tools TDM Systems (Mac) | 2 | 05-15-2003 12:16 AM | |
Building a new system. | JRuck | Pro Tools TDM Systems (Win) | 1 | 01-30-2001 04:17 PM |
