Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 01-09-2024, 11:41 PM
bolisound bolisound is offline
Default EUCon Network IP Address for tablets and S1s
Hi guys, I have a question regarding the to the EUCon network.
My setup is working, but I have some disconnection issues happening which is annoying. I am trying to troubleshoot the issue.
My setup is 2*S1 with Amazon Fire HD10, 1 Dock with iPad.
all dock + s1s connect to a router and connect to anker 577, then using an optical TB3 (40gbps) to computer M1.
The anker dock port are set to 192.168.1.xxx
The Wifi are set to 192.168.0.xx, all pad connect to it
in the EUCon surface tab, all the dock and s1s are with 192.168.1.xxx
all pad are 192.168.0.xx
I have dante staffs and mtrx sign to 169.254.xx.xxx
I am curius if this is correct for my network?
should all pad and dock s1s be in the same 192.168.(number for all pad and dock s1s).xx, or as long as they are under 192.168, then .x.xx doesn't matter, EUCOn will do the job?
And for the IP Address, should I have dock and s1 have lower number, than the pad or dock and ipad have lower number, then s1 and amazong fire with higher number, in short does the ip number bigger or smaller matters? if matter, matter for what?
I have read the extension://bfdogplmndidlpjfhoijckpakkdjkkil/pdf/viewer.html?file=https%3A%2F%2Fresources.avid.com% 2FSupportFiles%2FProMixing%2FEUCON_Networking_Guid elines_v2022.pdf
The setting doesn't seem to work for me.
should I use the same ip address like 192.168.1.xx for all my network, surfaces, and pad?
what is the most stable setting for network?
Old 01-10-2024, 09:16 AM
EddieJones's Avatar
Default Re: EUCon Network IP Address for tablets and S1s
Its hard to tell without a drawing of what is plugged where. But if the S1's and Dock are on the same network as the Tablets but have different subnet ranges 1 vs 0 in the third set of numbers of the IP address. Also, don't run Dantte on the same network as EUCON
Eucon network fix marsian Avid S1, S3, Dock and Control App 0 01-18-2023 02:30 PM
Can you connect multiple tablets with eucon/ avid control app? dawnofdreamx97 Pro Tools | Carbon 1 01-16-2023 11:48 AM
Tablets running Eucon app not connecting with S1 niviro Avid S1, S3, Dock and Control App 15 11-15-2022 08:14 AM
Pro Tools Network Activity- Multicast IP Address Dzerdzinsky Pro Tools 2018 0 04-12-2018 11:34 AM
Network Problems with Eucon?? peterle Artist Series 0 01-01-2015 04:12 AM
