Old 08-23-2023, 01:26 PM
michael c michael c is offline
Default Monterey 12.6.8 and PT 2023.6
I was on Monterey 12.6.5 and updated to 12.6.8 in Monterey. Now I am having problems opening some sessions. Anyone running 12.6.8 with no issues?
Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.6.8
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.6
HD Native Thunderbolt
Old 08-23-2023, 02:23 PM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
Default Re: Monterey 12.6.8 and PT 2023.6
I am running Monterey 12.6.8 and PT 2023.6 on a Mid 2012 Mac Pro with zero issues. Old sessions open just fine, etc...
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
Old 08-23-2023, 02:42 PM
Thanks for the info. All of the sudden I'm having random sessions getting stuck on loading a certain track.
Monterey 12.6.8
64 GB RAM
Old 08-23-2023, 03:30 PM
Well, if you get in a bind and have a session you can't open, I'd be willing to try and open it for you. You could PM me with a link to a Drop Box account with the session in it and I can give it a go.
Either way, best of luck to you.
Ghost
Old 08-24-2023, 04:37 PM
audiolex1 audiolex1 is offline
Rename the Pro Tools Icon to 2023.6. Install the last working version you used and name that icon to 202x.x (whatever year and version number)
Now you can go back and try opening the session and see if it opens.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 08-25-2023, 11:25 AM
MDGenerato's Avatar
MDGenerato MDGenerato is offline
Thanks.
Hi Michael! David here from the Community team. Are you still having some issues?
Old 08-25-2023, 02:02 PM
Hi David. Thanks for checking in. I originally updated from Mojave to Monterey 12.6.5 because of going up to PT 2023.6. I had no issues with opening some older sessions and everything was working great. But I went up to Monterey 12.6.8 and started having issues. After reinstalling PT, I still had the issue. So I bypassed every plug-in and put them in one at a time, restarting PT every time. Eventually I got to a few of our SSL plug-ins and I found a few that were causing the issue but only when those particular sessions were loaded in. It was weird because some of the SSL plugs from the same versions worked and many didn't.
So I have it all sorted out, but it's a huge drag that sessions from just a few years ago will now at least load in, but all the SSL EQ, dynamics and vocal 'strip' tracks will need to be remixed. I found later versions available but they are 'new' vs2, so though free, I can't see the setting on the original plug-ins. The previous plug-ins aren't just updated versions. I do music for TV and film and commercials, so somehow I'm always referencing past material and cues...
Thanks for checking in and also thanks to Ghost In The Attic and audiolex1 for their suggestions and help.
Monterey 12.6.8
64 GB RAM
Eucon 2023.6 Crashes often when using PT 2023.3 Selle Sellink Pro Tools 3 08-06-2023 02:29 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
Monterey 12.6 jackemski Pro Tools 6 10-03-2022 09:58 AM
M-Box 3 with OS Monterey philip_purcell FireWire & USB Audio Interfaces (Mac) 3 05-23-2022 09:25 AM
Monterey is now available Obsidian Dragon macOS 80 02-05-2022 10:52 AM
